1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
Loose Gear Shift On 5 Speed Manual???
Old 11-29-2009, 11:17 PM
rutang's Avatar
rutang
rutang is offline
Hi, I am a long time Ford truck fan but just got my first little truck. It is a 1994 Ford Ranger XLT (Extended Cab). It has a 5 speed manual transmission. Anyways I drove it home after buying it and it made alot of weird noises in the transmission. Plus the gear shift has a ton of play in it even when in gear and today if finally just gave out... the shift is just completely loose and I can't get it into any gear at all. What does this sound like? Something loose in the linkage or transmission gone out? Thanks for any insight or help!
Rusty
Old 11-30-2009, 07:30 AM
dorman68's Avatar
dorman68
dorman68 is offline
Sounds like your transmission ran out of fluid. The 5-speed manuals in the about 1992 & up Rangers have issues with the shift rail plugs seeping fluid as the trucks get older. I have replaced them on my truck already. I would first start by checking the fluid level and condition in your transmission. If you do a google search for Ranger shift rail plugs you'll find plenty of info.
Old 11-30-2009, 08:02 AM
powersmoked's Avatar
powersmoked
powersmoked is offline
the recomended fluid is Mercon.
fsaburro
22
05-20-2023 08:10 PM
skyler_estes
01-14-2020 10:10 PM
Bikerjoe
02-07-2017 01:29 PM
Jeneric
06-15-2016 09:38 AM
MRStace84
12-24-2010 08:06 PM
Quick Reply: Loose Gear Shift On 5 Speed Manual???
