Connecticut Chapter Join Chapter, Leader:
I think I lost my T-case
Old 11-28-2009, 10:24 PM
mercurycat's Avatar
mercurycat
mercurycat is offline
Well guys, I was driving back from my shop in my 92 F-150 and the truck soulded like it was prosessing gravel. Well I think My Transfercase went. I got under the truck and it looks to be the place. I am going to remove the shift motor tomorrow and turn it by hand to see if it stops. Any one have any ideas? She has some milage, only 240,000+ on her.
Thanks
Ken
Old 11-28-2009, 10:34 PM
Zookie400's Avatar
Zookie400
Zookie400 is offline
pull the drain plug and drain the oil, look for chunks and glitter. good luck!
Old 11-29-2009, 06:21 AM
gbroehl1's Avatar
gbroehl1
gbroehl1 is offline
Which case is it?
Old 11-30-2009, 03:37 PM
Aerocell4x4's Avatar
Aerocell4x4
Aerocell4x4 is offline
Diesel Van Enthusiast
Ken, how did you manage that?
I cracked a transfer case on my old GMC pickup truck.
Can't blame the truck manufacturer, as the transfer cases are vendor supplied.
I think I did mine in by using 4x4 to launch from a traffic light on wet roads, and a dry patch got me.
Now that I have locking hubs, I can't pull that stunt again till the snow flies.
Old 11-30-2009, 09:54 PM
mercurycat's Avatar
mercurycat
Do not know, I was dropping a 67 Mustang off at my shop and on the way home, the truck sounded like I was processing gravel. Now today, all is good..
Who knows
Old 12-01-2009, 06:49 AM
Zookie400's Avatar
Zookie400
check the front wheel bearings. often they will become worn/loose and allow the locking hub to partially engage making the nasty grinding noise you describe, and it will come and go.
El Campo
1999 to 2016 Super Duty
16
07-02-2016 02:52 PM
whynot95
06-02-2016 11:12 PM
Javier89F150
11-17-2015 10:58 PM
AntiHero55
43
05-21-2013 01:11 PM
Ken_C
03-05-2011 05:00 PM
Quick Reply: I think I lost my T-case
