Torque Specs for 2000 F-350 Wheel hub assembly
Old 11-25-2009, 07:34 AM
stemwill's Avatar
stemwill
stemwill is offline
Replacedthe left front wheel hub assembly on my 2000 F-350 DRW. I have two very different torque specs for the mounting bolts to the steering knuckle. One is 55ft/lbs and the other is 155ft/lbs. Which is correct or is it something different? Don't want to lose the $200-500 assembly(depending on where you purchase it)
Old 11-25-2009, 07:45 AM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
Hub bearing to steering knuckle nuts-55ft-lbs
Old 11-25-2009, 08:04 AM
stemwill's Avatar
stemwill
stemwill is offline
That was what I was thinking. 155lbs would probably snap/strip the studs or pull the assembly through the knuckle. Thanks.
Old 11-25-2009, 08:07 AM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
Originally Posted by stemwill
Thanks.
You're welcome
Old 11-25-2009, 08:16 AM
mueckster's Avatar
mueckster
mueckster is offline
Ford's spec is 133 ft-lbs.
Name:  hub to knuckle torque.gif
I've done a few of these and just used a long handle ratchet or breaker bar to tighten them up.
Old 11-25-2009, 08:53 AM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
I stand corrected
The specs I got were from a Chiltons manual.
Could they really be that far off like that
Old 11-25-2009, 11:37 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Chilton's?
Sure.
Those guys can be idiots. Their writers are..... writers, and are sometimes not very-well-versed in the finer points of wrench-turning.
A reasonableness cross-check would have caused them to investigate their published spec more carefully, but...... well, you know.......
And that's what we just did here, a reasonableness check. A lot of folks looked at that number and instinctively said, "Uhhh, let's look that one up again."
It just didn't look right, especially when it comes to holding one of the wheels onto a large pickup truck. You might find a Prius uses that number.
When in doubt, I usually consult Guzzle's pages, as he is a real stickler for details being correct. See:
http://www.guzzle7pt3.com/nblube.php
Pop
Old 11-25-2009, 12:00 PM
mechelement's Avatar
mechelement
mechelement is offline
Attachment 19063
133lbs-ft is what I used on those bolts.
Old 11-25-2009, 12:10 PM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
I'll stick with you guys and toss the Chiltons.
Old 11-25-2009, 12:15 PM
SpringerPop
Don't toss it completely, as there are photos in there that may contribute to your understanding of something.
They can't dork up a photo, at least not too badly....
Of course, they could show a photo that doesn't explain a thing, or even confuses, but.....
Just put the Chilton's on the bottom of the pile, and use it last.
Pop
Whitey Ford
11-01-2020 07:55 AM
Ryan50hrl
2004 - 2008 F150
08-18-2019 12:18 PM
Buck268
09-24-2016 11:00 PM
Shake-N-Bake
35
12-20-2015 07:48 PM
SpringerPop
08-14-2009 09:57 AM
Quick Reply: Torque Specs for 2000 F-350 Wheel hub assembly
