electric locker
Old 11-24-2009, 10:47 PM
cluv15's Avatar
cluv15
cluv15 is offline
electric locker
does anybody know if they make an electric locker for an 05 xlt supercrew with a 5.4 and I believe 9.75 rear end with 3.55 gears. I seem to be able to find it for every truck ever made except mine.
Old 11-24-2009, 11:26 PM
jstnromero's Avatar
jstnromero
jstnromero is offline
yeah they dont seem to make them, however detroit lockers or better limited slips without clutch packs are out there....here are some for you to take a look at.
Ford 9.75 Differential Positractions Auto Parts: AUBURN,AUBURN GEAR,LIMITED SLIP,POSI,POSITRACTION,DIFFERENTIAL,FORD 9 3/4,FORD 9.75,DETROIT,DETROIT LOCKER,LOCKER,DANA,DANA SPICER,SPICER,EATON,FORD,TRUE TRAC,TRUETRAC,AG 542090-HP,DET225C-194,DS 73106
hope this helps.
It is odd that there are no real e-lockers out there for the 9.75. I guess your only option is to take the rear pumpkin and beef up the limited slip. Then if you have 4WD you could take the 8.8 front end and put an e-locker in that.
~Jstnromero
On Edit: We have a Detroit Truetrac on my dad's superduty and it performs wonderfuly. It is locked when we need it and unlocks when turning. It is a very solid unit that has no clutchpacks to deal with so pretty much zero maintenance other than changin the fluids at the required times.
kcducttaper
1999 to 2016 Super Duty
18
06-24-2016 08:33 AM
93-331-29PSI
6.7L Power Stroke Diesel
55
12-14-2015 06:36 PM
A Rodder
11-20-2015 01:32 PM
amstel78
02-19-2014 10:52 AM
MM1281
2009 - 2014 F150
60
04-04-2008 02:15 PM
Quick Reply: electric locker
