Oil Leak from Oil filter on 5.4L Ford HELP PLEASE
I am at a loss This truck has benn down for a while and i finally got the parts and money to deal withit and now this. While the truck was just sitting in my garage not being driven for a lil over a year I walked in one day and saw all the oil on the ground i follwed it back to the oil filter and just thought that the truck did have alot of rust under it and maybee the filters rubber seal went. so I replaced filter and oil with all new. I finally finished the truck and it started right up but when I looked under it I saw OIL POURING out of the filter to the ground coming from one spot on the drivers side of the top of the filter where it seals to the truck its not all the way around the filter just one spot and when the truck is running it is literally pouring out. I shut off the truck and inspected for damage there was no visible damage and filter was tight. I havent pulled filter off yet but I have NO idea what this could be. PLEASE HELP WITH ANY SUGGESTIONS THANK YOU IN ADVANCE.
Ok so I checked an the old seal was gone there was some corrosion build up so I cleaned it and it was only in the spot where it was leaking from so I thought sweet problem solved. Nope it's still pouring out when I start the truck I am positive it is coming from top of filter where seal should seal I am at a loss I can't even comprehend how I mean the seal is making a clean seal i don't know how the oil can get around it to pour out. I don't know what to do.
I have a 150 and 250SD. How much work is involved in switching over to the oil cooler mounted filter on the 150? This 150 has had this leak issue for months. I've done the block/housing o ring twice (not a happy time). My 250SD has never left a drop. Does the engine mount have to swap as well?
Talltruck
10-26-2015 11:09 PM
BIG-DADDY-F350
01-11-2015 09:49 AM
QwkTrip
2009 - 2014 F150
31
08-15-2013 02:25 PM
wezol5484
02-23-2011 02:50 PM
