dual rear wheels
Old 11-07-2009, 09:14 PM
projectdagger's Avatar
projectdagger
projectdagger is offline
dual rear wheels
I have a 77 f-250 two wheel drive. Over in the local wreaking yard there is a 79 1-ton dually. I starting thinking about buying the rear duals off the one ton. My question, Do i need to make any modifications to the rear axle to bolt up the wheels? OR could i just bolt the wheels on?
Old 11-08-2009, 02:16 PM
Supercab's Avatar
Supercab
Supercab is offline
Wink
I tried this many years ago and it won't work-I think you can swap the complete rear end though-or go and check out Arrowcraft - Dual Wheel Conversions for a quality adaptor kit to do it with your current rear.
Old 11-08-2009, 02:41 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Supercab
I tried this many years ago and it won't work-I think you can swap the complete rear end though.
Dana 70: The rear end makes no difference whether it has SRW, or DRW.
What is different are the hubs, drums, lug studs and etc.
F250's were not available with DRW's.
There were no Styleside pickups available with DRW's until 1980, and then...F350's only.
Prior to 1980, all F350's with DRW's were sold as a Cab & Chassis, or with a factory installed flat or stake bed.
Old 11-08-2009, 02:46 PM
cjstang32's Avatar
cjstang32
cjstang32 is offline
Also, the frame on the F-350 is probably 34" wide while your frame (unless it's a high boy) is 37.5" wide. Chances are the inner duals would rub.
Old 11-08-2009, 03:05 PM
NumberDummy
1967/77 F250 4WD's (High Boys) have rear frame rails that are 33 1/2" apart.
Some F350's thru 1979 also have these narrow frame rails, some have frame rails that are 37 1/2" apart.
All other 1973/79 F100/250's have rear frame rails 37 1/2" apart.
Old 11-08-2009, 05:00 PM
lostinfords's Avatar
lostinfords
lostinfords is offline
I have a dual rear wheel adapter kit on my f250 4x4 crew that I am not going to use...I know it was an add on but it is available, pm me if anyone is interested in it.
Arrowcraft does not make the drw fenders for the dentsides any more. I sold a set to a guy in Colorado from my 77 crew cab, I just took the duallies off and put on aftermarket 10" wide rims.
Old 11-08-2009, 05:25 PM
1800joedaddy's Avatar
1800joedaddy
1800joedaddy is offline
Just got through doing my fronts, they're a direct bolt on. It was said earlier that there is no difference in the rear? Only about 4" inches a side. It's true the hubs and parts will interchange but the axle width is shorter in relation to the DRW. Just swap front hubs and the complete rear and save $ over the arrowcraft stuff which is not as strong and will cause problems if you load it heavy, say with a gooseneck.
I'm using these fenders.
My front hubs cost me about $50 and they take standard 1 or 3/4 ton bearings.
Pm me or check my build if you need help. Good Luck!
Old 11-08-2009, 10:49 PM
projectdagger
If i could, i would just buy the whole from the wrecking yard. But the owner will not sell it complete. My truck and the one ton dually is a 2 wheel drive. So if i buy the complete rear axle from the one ton. Would it bolt into my f-250?
Old 11-08-2009, 11:18 PM
1800joedaddy
Measure the distance between the pads to be sure but I'm going to say yes.
Richard H.
08-15-2016 10:43 AM
kb9nvh
1999 to 2016 Super Duty
04-22-2015 06:22 AM
jon on the mon
09-23-2014 01:54 AM
1978fordf250
04-22-2008 09:17 PM
mediumfry
01-02-2003 04:27 PM
Quick Reply: dual rear wheels
