1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Limited-slip Rear end
Old 11-02-2009, 08:43 PM
Nick2005f250's Avatar
Nick2005f250
Nick2005f250 is offline
This may be a stupid question but, is there anyway to lock a limited-slip rear end. How exactly does limited-slip work is it electronic, can I enguage it by a toggle switch, or would I have to just install a posi lock locker. I don't want to weld it because I still use the truck as a daily driver. It can be a pain in the *** to have one rear tire spin and my truck almost get stuck before I stop and lock the hubs. Any answers would be helpful. thanks.
Old 11-02-2009, 08:50 PM
Pinky Demon's Avatar
Pinky Demon
Pinky Demon is offline
A limited slip works by sensing torque and traction and then distributing as needed. There is no way to lock them. You are thinking of a locker, where the axle physically locks together, vs. a posi-traction where it is a torque biasing unit. You can however, get a locker that is activated by air compression. ARB makes them. Downside is, they cost about 1k or more to get it all together. I am personally going with a Detroit Truetrac limited slip to be used when snow plowing. I received the unit today, from Randy's Ring & Pinion. The Differential Experts. Auto Parts & Services.. They are very knowledgeable and can definitely help you out. Whatever you do though, do not, I repeat, do not, weld your unit.
Old 11-02-2009, 08:56 PM
Nick2005f250
Thank you, yea someone i know welded his rear end in his jeep and he said it squeels around corners. it didnt seem like a smart thing to do... expec. with tires going for 200+.
Old 11-07-2009, 03:48 AM
GregsSD's Avatar
GregsSD
GregsSD is offline
The factory limited slip is garbage! Mine only spins one tire now days.
You need to replace the stock limited slip with a Detroit Trutrac or a Detroit Locker if you want reliable traction.
Old 11-07-2009, 11:02 AM
Big_Al59's Avatar
Big_Al59
Big_Al59 is offline
Did you ask this in the off road forum? Lots of knowledge there. I think some of the e-lockers normally work as a posi but can be locked in to work as a full locker when the need arises.
Old 11-08-2009, 12:03 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
guy i know welded his rear end in his jeep
That's called a Lincoln locker, and really should not be used on a DD that see's mostly pavement. The stock LS is garbage, it works based on a clutch pack engaging when one tire breaks loose, but it doesn't ever seem to hold up in the real world. Buy either an Eaton LS unit, or just spring for a Detroit locker, they won't ever fail in a stock setup
Old 01-26-2010, 10:15 PM
ssthomps's Avatar
ssthomps
ssthomps is offline
Hey, I know this is a bit dead, but has anyone had any luck getting the dealer to cover the LSD beginning to slip excessively under warranty?
Old 01-27-2010, 06:50 AM
in heat's Avatar
in heat
in heat is offline
change the fluid and get the friction modifier, this helps quite a bit, I installed a truetrack and I love it ( all kinds of traction)
Old 01-27-2010, 07:45 AM
aldridgec's Avatar
aldridgec
aldridgec is offline
@ ssthomps. Sometimes they will cover it. Depends on the dealer as with most things. I've had them replace the clutches before.
Old 01-27-2010, 08:22 AM
dkf's Avatar
dkf
dkf is offline
The LSD on the SDs is nothng more than a preloaded clutch pack, with little preload I might add. No way I would spend a dime rebuilding the stock unit. Go with an aftermarket unit like the Truetrac.
Old 01-27-2010, 10:39 AM
ssthomps's Avatar
ssthomps
ssthomps is offline
Well the trucks still under warranty, and i'm broke college student. So I'll have to wait to get back to a summer job to buy a truetrac
Since you all are being so helpful today. I have a transfer case problem too:
I will be rolling up to a stop sign and flip the switch in 4x4 I hear it engage, the 4x4 light comes on. I come to stop, proceed away from the stop sign, at this point there is a loud slam, the truck is now in 2wd, there is lots of grinding noises, another loud slam, and it now stays in 4x4 until I switch it back to 2wd. I took it to the dealer, the said the changed a solenoid, didnt help. The snow up here will not work with me and the roads are always clear when I have time to take it in. you guys got any leads that I can give them when I take it in. The guys there just look at me like im crazy and this is impossible.
Old 01-27-2010, 01:45 PM
bbender85's Avatar
bbender85
bbender85 is offline
Originally Posted by in heat
change the fluid and get the friction modifier, this helps quite a bit..
change the fluid and use less or NO friction modifier... when i did my fluid i only used half the recommended friction modifier and it still didnt improve the LS much. next time i don't plan on using any.
Old 01-27-2010, 04:52 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
Excellent advice. I always recommend starting with no modifier. If it chatters, add a little. Add a little at a time until chatter goes away.
With Redline 75W140, I used 0 modifier and my LSD works great, even with 160K miles and bone stock original diff. It was fun pulling all the diesels out of the sand! I would consistently fling sand with 3 tires.
Old 01-27-2010, 05:14 PM
bbender85's Avatar
bbender85
and for the record, i remember reading royal purple diff fluid already has the friction modifier in it... so if you are looking to restore some life in your LS by running little/no FM, keep that in mind.
Old 01-27-2010, 06:49 PM
motor-man's Avatar
motor-man
motor-man is offline
Alright guys i need a little help here, i'm completely clueless when it come to this stuff.
When you say yours only spins one tire now days, is the LS suppose to spin both? I thought LS meant if one tire spins the other one stays tracking?
Can someone also further explain the difference between a locker rear end and a posi?
I'm just not a fan of the "one wheel peel" (catch s**t from my buddies all the time because of it), and i don't have the $ right now to invest in an aftermarket one like you guys are speaking of.
Thanks, btw I have a 2007 f250 PSD.
Quick Reply: Limited-slip Rear end
