Play in drive shaft
Old 10-31-2009, 06:55 AM
ltl_jrw's Avatar
ltl_jrw
ltl_jrw is offline
Play in drive shaft
Not a lot but I can turn (rotate) my drive shaft some, my transmission is in park. Is there anyway to tighten the rear yoke to take up the slack? Also should there be any slack in the transfer case. My truck is a 99 F350 dually 4:10, what rear end is under my truck, a Dana or what?
Old 10-31-2009, 07:15 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
How much can you turn it? Theres always a little slop.
Old 10-31-2009, 07:16 AM
mxracer3276's Avatar
mxracer3276
mxracer3276 is offline
Most dually's are equipted with Dana 80's in the rears. As for the play, i am not sure, might be a symptom of the carrier bearing going out, not sure though, more will chime in.
Old 10-31-2009, 08:48 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
The duallys' have a Sterling
Old 10-31-2009, 09:43 AM
ltl_jrw's Avatar
ltl_jrw
ltl_jrw is offline
Thanks to all. How would I know if it's a Sterling or a Dana 80 ? As for how much slop, I can turn it about an an about a 1/4 inch.
Old 10-31-2009, 10:45 AM
Kwikkordead
Is it kind of like this?
If so, no worries.
P1040615.MOV videos from trucks videos on webshots
Old 10-31-2009, 11:05 AM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Dan,
Nice videos for the in-experienced, like me, to use for comparison.
Reps to you.
Old 10-31-2009, 04:14 PM
ltl_jrw's Avatar
ltl_jrw
ltl_jrw is offline
If so, no worries.
Yep thats what I have, no more than that
Old 10-31-2009, 05:24 PM
Kwikkordead
Originally Posted by PaysonPSD
Dan,
Reps to you.
Thank you.
That's just the parking gear. Drive it and enjoy.
Old 10-31-2009, 06:29 PM
ltl_jrw's Avatar
ltl_jrw
ltl_jrw is offline
Thank you.
One more question, I understand the parking gear having that much slop BUT should there be that much with the truck on the ground, I bet that video was when the truck was on a lift.
Old 11-17-2009, 05:25 PM
ltl_jrw's Avatar
ltl_jrw
ltl_jrw is offline
With all the tires on the ground should there be any slop in the drive shaft? And if not how do you get slop out of the rearend?
Old 11-17-2009, 06:09 PM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
You will still have slop with the wheels on the ground.
Old 11-18-2009, 05:13 AM
ltl_jrw's Avatar
ltl_jrw
ltl_jrw is offline
Thanks, I just thought that the pinion should not have any slop. I don't like that and thought there was wear in the ring and pinion.
Old 11-18-2009, 07:18 AM
Kwikkordead
You need a little bit of play to allow the gear oil to get in between the teeth.
Also there will be more slop on the spiders than the ring and pinion.
You may be feeling that slop vs the bit of space allowed for the ring and pinion.
TheRooster
01-24-2017 08:24 AM
fast_lap
10-08-2016 07:04 PM
cuazman
05-21-2016 06:29 PM
F350Man79
1999 to 2016 Super Duty
12-30-2015 08:53 PM
4dman
15
11-14-2001 06:45 PM
Quick Reply: Play in drive shaft
