No cruise or horn. NOT the clock spring though
Well, I just got done swapping out the clock spring on my Excursion because the horn and cruiser will not work. Still having the same issue now and I know I did it correctly. So, what else is left?
I will say that the horn engagement seems really wierd on this. Its like its not spring loaded at all. Normally when you push a horn it will feel as if there is a spring, but not on this X. I am curious if that may be the issue or may have something to do with it.
I have also check fuses as well and they are good.
FWIW, the airbag system is working correctly and the horn will sound with the alarm, so I know its working. Any ideas?
Wiring looks fine. Casing still intact and no indication of any wear issues or chafing other than this issue on my ***.
on
I had a similar thing happen last winter. I ended up giving up and taking it in. They replaced the wiring on the brake master cylinder, (on the end of it there is a wiring harness) and then they traced it to the cruise control module. There is a recall for that switch on the brake master cylinder so you can phone in your vin and they should be able to tell you if it was ever upgraded on yours, or take it in and they can look at it and should be able to tell. Mine was replaced, and still had the same problem.
Here is a picture.
Here is a picture.
Here is a picture.
Here is a picture.
on
it is the cruise control module.. it happen to me.. had the wire harness off the master cylinder replaced and then found out the the module was burnt out at the connector... it cost like 300 for the part if im not mistaken.... if u disconnect the module and disconnect the wire harness by the master cylinder and make sure all your fuses are good the horn will work
The cruise control module is located on the passengers side fender right in front of the A/C unit. My module burnt out were the wire harness plugs into the unit. If u don't want to get it fixed because you don't use the CC the just unplug the brake switch harness that plugs into the master cylinder and make sure the fuses are all good and the horn should work. I will check tomorrow to see if I still have some pics and info on all this
