18984 F250 Wheel interchange with other brands ( Chevrolet, GMC, Dodge )
I have seen some posts on this subject but am still confused.. I am looking for some wheels with tires mounted on them and want to know what fits my 1994 F250 . Is there a chart or list somewhere ( web link ?) - Thanks
You have an 8 lug right? I did some research on this, but don't remember all the numbers off the top of my head. I do remember the Dodge trucks (it was an older generation) used a metric 8 lug, that when converted to standard was the same as the ford 8 lug. Go on a few web sites that specialize in rims, and one of them is bound to have the popular lug patterns. Then you just compare a few and see what you get. That's how I found the Dodge.
80-97 f250 and 350 use a 8 on 6.5 pattern
80-current dodge use a 8 0n 6.5 pattern
80-current chevy use a 8 on 6.5 pattern
-Now FORD fell off their rocker in 98 and went to a 8 on 170mm
-chevy stock wheels have a smaller center hub and will not fit a ford without machining
Dodge wheels will fit as far as i know
As for aftermarket wheel, i believe they are all the same for 8 on 6.5 pattern
Aftermarket Eagle Alloys 1459's are now on my 63, which came off a 87 chevy. If you are looking for stock take-offs, as stated, some chevy rims will need the center machined, if you are going aftermarket, most of them come with the larger hole, I would peruse the ol' craigslist in and around your area, I have bought 2 sets, W/tires on craigslist each set of 4 for 2 bills.
SUPERDUTYOKIE
01-18-2014 07:21 AM
