Michigan Chapter Join Chapter, Leader: Toyman
truck just shuts off..?..on my 2002 f250 triton v10-? fuel filter changing?
Old 10-24-2009, 12:08 PM
timholmes's Avatar
timholmes
timholmes is offline
has anyone ever changed there fuel filter on a 2002 ford f250 tirton v10..the primary filter under drivers seat on rail bottom under truck and the secondary fuel filter under the hood...looking for some tips before i get into it..
today when i started the truck, took off and drove 1 block and it shut off and died when i was driving, ouked over tried to start it , nothing just keep trying to turn over...waited then it started and i made it 1 whole block and the same thing happened..then i did the same procedure and hobbled back home ...told by my gear head freinds that it is probally the fuel filters and maybe the fuel pump? i have 130 k on the engine i bought the truck used from someone when it had 108k on it. thanks for any help u might have.....MIDWEST!!!!!!!!
Old 10-24-2009, 12:26 PM
Talyn's Avatar
Talyn
Talyn is offline
Changing the fuel filter will be good if it fixes the problem or not.
Can you hear the fuel pump run when you turn the key on but don't start?
Should be some sorta hum, not sure though.
Old 10-28-2009, 11:22 AM
just another truck's Avatar
just another truck
just another truck is offline
I would have voted cam position sensor, William, any way of moving him into one of the superduty threads?
Old 10-28-2009, 08:55 PM
Toyman's Avatar
Toyman
Toyman is offline
Hey Tim, long time no see. Glad you got into the Ford family. Did you get the truck running by changing the filter?
I know you can't figure who this is by my "name" here, actually last time we ran into each other was at Hooters. Ironically enough we are have a get together there on the 7th, show up before you head to Cali.
To take the question out of who I am......Rich Yonkers.
Old 10-28-2009, 10:15 PM
Talyn's Avatar
Talyn
Talyn is offline
Uhm, pat, its a v10, not a PSD. =)
if that it would be a "crank position sensor"
Yea, tim. You should post this in the v10 forum to get the best help. Only one person here has a v10 that I know of, and that is green machine johns dad.
oh, dan's uncil or somebody he knows has one also.
Old 10-29-2009, 10:35 AM
just another truck
Agreed, but I still stand with the CRANK position sensor. I am pretty confident in that answer though.
Old 10-29-2009, 12:21 PM
Talyn's Avatar
Talyn
Talyn is offline
You didn't say crank before. :P
har har har har har!
Yea, CPS does all sorts of strange things when they go bad on gassers.
Old 10-29-2009, 12:51 PM
just another truck
as well as smokers...
Old 01-18-2010, 08:24 AM
fordmasterdieseltech's Avatar
fordmasterdieseltech is offline
i vote crank sensor as well. fairly common on the v-10 of that year.
D.Yaros
1999 to 2016 Super Duty
06-15-2018 01:25 PM
Todd Rasmussen
Modular V10 (6.8l)
07-09-2016 10:44 PM
gary.aderhold
50
12-11-2015 05:48 PM
James92
Modular V8 (4.6L, 5.4L)
11-25-2015 05:18 PM
Quick Reply: truck just shuts off..?..on my 2002 f250 triton v10-? fuel filter changing?
