Whos going to order a 6.2L?
If the 411hp and 434ft/lbs are correct numbers for the 6.2L, then my next 2011 or 2012 SuperDuty CC Auto 4.30 4x4 will have the 6.2L. I am sure...those are conservative numbers too. That engine has so much more potential...
What I have said in the past...is the 6.2L must provide more torque than my current V10 in order for me to consider it (wasn't concerned with hp numbers). If the numbers hold up...6.2L all the way. However...I will be leaving mine all OEM stock.
Just in case any are interested...my '03 V10 has 310hp and 425ft/lbs torque.
biz
biz
Yes, it should compete with the V10. Probably not for RV applications like Class C's ,etc... nor towing above 10K, but for the rest it should work well. I have owned many 8.1L GM's with 4sp/4:10's running gear. They discontinued it, so I took a chance on GM's 6.2/6sp/3:42, and it suprisingly did well compared to the 8.1. Not equal, but good enough to get the job done. I now own two GM 6.2's. I tow 8K through the Appalatian mountians a lot, but not enough to buy a specific tow vehicle with a diesel that stinks as a daily driver.
Ditto! And I see just how you have only 83 posts with your irrelevant comments to a thread! Either post something related to the thread...OR...go take a jump. Makes no difference to me.
biz
Why hold back? You should share how you really feel. Why take it so personally? I wasn't intending on being mean. You on the other hand....
plunge
I took a chance today and ordered a 2011 F350 with the new 6.2 and 6 speed auto. I had to replace a 02 with a 5.4, 6 speed stick and 360,000kms. The heads are rotting at the manifolds!!
I never order first year or job1 items but I need a new truck to replace this one desperately. I have my fingers crossed. Should be in late March or early April. I'll post a couple reviews shortly after.
Tim --------->>>>
Tim --------->>>>
