1966 f100 voltage regulator
Old 10-19-2009, 11:14 PM
danno_eleven's Avatar
danno_eleven
danno_eleven is offline
There is 2 wires coming from the A part of the plug (I believe its the A). The previous owner cut one of them. I have the rest of the wiring going where it is supposed to. Where could this second wire go? The owner of the truck led me to believe it was a 65, but upon further inspection of the vin numbers, I came to find out it is a 66. Unfortunately, I ordered a wiring diagram for a 65. How close are they? The 65 diagram does not have this mysterious 5th wire on it. Any help is appreciated.
Old 10-19-2009, 11:50 PM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
Are the wires yellow? Does the second wire still have the male connector on the end? Well it should since that wire goes to a radio suppression condenser attached to the base of the voltage regulator.
Old 10-20-2009, 04:16 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
D4TZ10316A .. Alternator Voltage Regulator / D4TZ10316A replaced C3SZ10316B.
Fits: 1963/81 Thunderbird / ALL 1965/81 F Series Trucks, Bronco's, Econolines, Passenger Cars.
The plug (only) for the regulator is the same 1963/64 T-Bird / 1965/96 everything else.
Old 10-21-2009, 12:19 AM
danno_eleven
Yes it is the yellow wires. There is nothing at the end of the wire. It is cut about 3/4 of an inch from the plug. The voltage regulator I have is Napa brand. There is nothing at the base of the regulator. NumberDummy are those the part numbers? And what does a radio suppression condenser do?
Old 10-21-2009, 02:43 AM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
Without radio suppression you can pretty much hear your spark plugs firing when you have your radio on by all the pops.
Old 10-21-2009, 02:51 AM
NumberDummy
Originally Posted by danno_eleven
NumberDummy are those the Ford part numbers? Yes.
Eliminates ignition interference with the radio.
Ford did this:
C3SZ10316B .. Alternator Voltage Regulator was replaced by D4TZ10316A in 1974.
In 1982, D4TZ10316A was replaced by E2PZ10316A ... which is an electronic regulator.
In 1990, Ford replaced E2PZ10316A with this electronic regulator: FOPZ10316A (Motorcraft GR540B). This part number is still current.
The regulator's wire plug is the same for all of these.
When Ford went to the electronic regulator in 1982, **** car/truck collectors (like myself) were not pleased, because the electronic cover is flat, dull aluminum in color and has MOTORCRAFT embossed on it.
The simple solution is...remove the cover from the original regulator, install it on the electronic regulator. Now...no one will know the difference.
Why some of us do this: It has everything to do with correct and/or concours restorations.
There was no such thing as Motorcraft prior to 1973. So....the last thing someone wants on a 1972 or earlier vehicle...is a cover that sez MOTORCRAFT on it!
Old 10-22-2009, 10:53 PM
danno_eleven
Thanks alot guys. I really appreciate the help. I'll keep you posted on my charging situation.
Old 10-23-2009, 08:42 PM
ol yeller's Avatar
ol yeller
ol yeller is offline
My wire on the back of the altenator was corroded in the insulation and caused me grief. Might be worth a look.
Old 10-24-2009, 12:04 AM
danno_eleven
I actually replaced all the wires. A few of them were corroded. I basically just remade the loom. Used the same gauge wire, new regulator, new alternator, new battery. Still wont charge properly. I also used dielectric compound on the regulator plug, and some of the other plugs on the truck, and cleaned all the grounds.
EricJ
66
10-17-2021 06:19 PM
hath
08-10-2017 11:12 PM
horserder007
02-20-2013 12:44 PM
urbex
05-08-2012 05:51 AM
65stakebody
12-31-2011 03:46 AM
Quick Reply: 1966 f100 voltage regulator
