Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
1988 150 lariat fuel problem
Old 11-07-2002, 06:17 PM
jim dog's Avatar
jim dog
jim dog is offline
Post 1988 150 lariat fuel problem
i have been having a problem with the fuel system in my truck./
a little history
the truck had been setting for about year
had to replace clutch
then i had to replace tank and front fuel pump
ran for about month then it quit on my son and he had it towed to a place in orangeburg, my wife spent $500 on replaceing the same fuel pump that i had just put on.
well they drove it back to elko and it quit running again.
when i got home i picked it up where they left it and it cranked right up, i started to drive it back home and it start sputering,coughing and basicly quit, it started back up about 5 minutes later and i drove it maybe 3 miles and it starting missing again, as long as i was pumping the peddle it would start again i finally got it home and thats where it is setting now.
i'm not much on fuel systems as this problems seems to be.
any input would be appreciated.
thanks
jim in elko
Old 11-10-2002, 06:54 AM
bmoran's Avatar
bmoran
bmoran is offline
Jim,
You might want to try changing the "sock" in the fuel tank. It's at the suction end of the tube in the bottom of the tank and when they clog it gives you the symptoms that you describe. If they didn't change it when they changed the tank it's probably clogged with rust, etc..
Unfortunately, this can drive you nuts trying to find. About the only way to do it is to get a fuel pressure gage and drive the truck with the pressure gage hooked up and watch it when the truck starts to run poorly. If the fuel pressure is dropping, then you have a problem in the fuel delivery and since you have replaced most of the other pieces, this could be the issue.
Bill
Old 11-17-2002, 08:03 PM
Brett200's Avatar
Brett200
Brett200 is offline
TiredBestFriend
11-06-2014 04:46 PM
big poppa
56
01-20-2011 11:51 AM
fastmover
N. California Chapter
09-19-2007 04:59 PM
fastmover
36
07-23-2007 12:14 PM
les017
2004 - 2008 F150
07-17-2005 07:00 PM
Quick Reply: 1988 150 lariat fuel problem
