1977 Highboy before and after lift comparison pics
I looked for pictures of this combo before i lifted mine and came up with very little so I thought I would post them for future reference. 1977 F250 Highboy 4" skyjacker all spring lift 38x12.5 swamper tsl 460 [IMG][/IMG]
[IMG][/IMG]
__________________ Darin I BLEED BLUE 76F250 66 fairlane dragcar514
1997 F250 HD 7.3,3.55-4.10 swap done,156k,140VIDM,HPX, 3-4"tymar w 4"straight pipe,ccv mod, S366 turbo, DIY 6637, elec. fuel,rosewood stage ones,php tunes,T500 HPOP,180 tstat,6.0 fan,6.0IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and triple disc billet converter, upgraded trans, F550 leaf springs,mean green alternator and starter,SD dual tensioner upgrade, cold ac mod
The tires are the original bias ply tsl the ride is interesting to say the least. The wheels are 16.5x8.75 I kept the stock rear blocks when I installed the lift springs.
Cool, thanks for the info. I'm with you on the bias tires, I'm running bias-ply 36" Goodyears right now. The drive to work in the morning is pretty, umm, animated for the first few miles...
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. FordŽ is a registered trademark of the Ford Motor Company.
