Turn signal relay location??
Old 10-14-2009, 12:20 PM
dvldog458's Avatar
dvldog458
dvldog458 is offline
Question Turn signal relay location??
I just replaced my turn signal bulbs with LED replacements and when I actuvate my turn signal it blinks very fast.
I think if I upgrade my turn signal relay to a heavy duty or electronic it should do the trick and slow things down.
I looked in my manual and could not find the location. Has anyone replaced their relay/ And if so where is it located? Or any pics would be great.
Thanks
JD
Old 10-14-2009, 01:37 PM
tdappleman's Avatar
tdappleman
tdappleman is offline
The blink speed is a common problem when going to LED bulbs - it's due to different resistor values of the bulbs. I had looked into doing this on a different car and bookmarked this site: Tail light and Turn Signal LED Bulbs Fix
Old 10-14-2009, 05:41 PM
dvldog458's Avatar
dvldog458
Nice link. Thx
I will look into it.
Old 10-15-2009, 09:48 PM
dvldog458's Avatar
dvldog458
Well, I installed a Napa heavy duty relay part# EP-27 and I still have the same problem.
As far as it's location....it's in a pretty chitty spot. Under the dash right of the fuse panel near the small storage compartment.
Any other ideas?
Old 10-16-2009, 06:11 AM
shorebird's Avatar
shorebird
shorebird is offline
Old 10-16-2009, 06:25 AM
tdappleman's Avatar
tdappleman
Looks like a good solution if it works... love this text from the auction:
Load resistors are a fire hazards, because they get VERY HOT.
It is like installing a Toaster to solve a simple flash problem…..
It's not like these resistors have a load going through them at all times so heat doesn't really get a chance to build up - unless you left your hazards on - maybe that would build up a bit.
Old 10-16-2009, 08:13 AM
dvldog458's Avatar
dvldog458
Good info guys. Thx. I just noticed this morning that when I use my 4 way hazard button they blink at a normal speed. But when I use only the left and right they blink Very fast. Does the 4 way use a different relay?
I
I
Old 10-16-2009, 03:49 PM
dvldog458's Avatar
dvldog458
If I have to install an inline resistor I will....but for now I'd like to find a simple push in relay/flasher.
I found this place:
LED Flashers Blinkers Resistors Load Equalizers for Turn Signal Replacement Bulbs Rapid Flashing Fix
Old 10-17-2009, 11:16 AM
RACERX7775's Avatar
RACERX7775
RACERX7775 is offline
dvldog, when i made my taillights using the 4" round tractor trailer led lights, i used the load resistors. i have had mine inside the rear taillight housing for about 2 years now. no problems.
Old 10-19-2009, 09:49 PM
dvldog458's Avatar
dvldog458
Thanks for all the ideas and help guys.
I went ahead and purchased the LED flasher relay fix (link above) and it works perfect. I just pushed the new relay in and it was good to go!
Old 02-26-2010, 04:25 PM
gmcbride's Avatar
gmcbride
gmcbride is offline
I know this link has not been active in awhile, but can someone please tell me, with some specificity, where the darn flasher is. call me stupid, but i cannot find it. i have the fuse panel off, turn on the hazard button, can hear it, but just can't locate it? thanks very much!
Old 02-22-2011, 08:42 PM
jay1000's Avatar
jay1000
jay1000 is offline
Exclamation flasher location
Thanks
JD
your flasher relay is easy to find. if look at the bottom of the dash below the radio, you will notice that the panel comes apart. it has four screws this panel is part of your cup holder and ash tray .once thats down and out of your way, look in the dash and its right in front of you. in side of a black box. remove black cover by prying it open its the blue relay in side.
Old 02-26-2011, 01:46 AM
1buckeyefan's Avatar
1buckeyefan
1buckeyefan is offline
I need to replace mine. Does anyone have a photo of where this is??
Old 02-26-2011, 06:25 AM
Paultv's Avatar
Paultv
Paultv is offline
The easiest way to find it is to turn the flasher or blinker on and stick your hand under the dash where the radio is, and there is a black box, just keep grabbing things with your hand and you will feel the thing ticking, it's in the most stupidest place I've ever seen a flasher.
Old 02-26-2011, 06:05 PM
RACERX7775's Avatar
RACERX7775
Originally Posted by Paultv
The easiest way to find it is to just keep grabbing things with your hand and you will feel the thing ticking.
sorry, i edited it a bit. thought it was funny.
Quick Reply: Turn signal relay location??
