2008 F250 6.4L Diesel Fuel Filter part #
About to do my first fuel filter(s) change. The owner's manual says the part # is FD4604. Motorcraft.com and dieselfiltersonline.com say the part # is FD4609. Amazon.com say both will fit my truck.
Does anyone if there is a difference between FD4604 and FD4609? Will both fit??
Thanks
Thanks
https://www.fleet.ford.com/maintenan...ls/default.asp
It is found under the maintenance tab.
On edit:
I don't think they have the diesel supplement there, and that is what you need. Try here:
http://www.motorcraftservice.com
No need to log in, just click on the owners manual tab on the left side of the page.
On edit:
A service tip for you on the filter change I had with my 08. Upon putting on the new filters and cycling the key the 6 times per the manual my truck would not start. I could get it to catch briefly was about it.
I learned that holding down the fuel cutoff switch while cranking I was able to get it primed and running.
My switch is sensitive is the only explanation I have.
Switch is on the passenger side of the dash. Open the door and you will see the access panel on the side of the dash.
hank89
12-13-2011 08:34 AM
97C5ENVY
6.4L Power Stroke Diesel
11-11-2009 08:44 PM
