Arizona Chapter Join Chapter, Leader:
Both my door locks are busted!!!
Old 10-29-2002, 06:21 PM
bronco351's Avatar
bronco351
bronco351 is offline
Hi, i have a 1990 Ford Bronco XLT. Recently mr drivers side power door lock stopped working. Then yesterday my passenger side door lock stopped working I was wondering if any one here knows of a junk yard that has some Broncos so I can get a set of power door lock motors. I don't want to keep using th ekey it's a real hassle. it was not so bad just one door but both. What a PAIN!!! Thanks for all your help!!!
Old 11-07-2002, 02:04 PM
honney's Avatar
honney
honney is offline
I had the driver's door lock solenoid die on my '90 Bronco as well. Replacement isn't too bad but first make certain your switches aren't corroded, will the passenger side switch engage the locks?
Old 11-07-2002, 02:28 PM
bronco351's Avatar
bronco351
No, neithrer switch works. But, every once in an while the passenger door will work!
Old 11-07-2002, 08:57 PM
jbearford's Avatar
jbearford
jbearford is offline
