Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Bleeding a Hydrovac Brake System
Old 10-07-2009, 11:56 AM
rb48f6's Avatar
rb48f6
rb48f6 is offline
This information was provided in another thread that was covering several topics. It was suggested that it be split out into a new thread as it may be beneficial to others as well.
Bleeding A Hydrovac Brake System, Manual
Manual bleeding requires filling the master cylinder reservoir and pumping the brake pedal to force the fluid through the lines to expel air from the system. This operation must be done with the engine shut off and no vacuum in the power brake system.
With the master cylinder reservoir filled, open No.1 bleed screw on the Hydrovac and depress the brake pedal to expel air. When the brake pedal has reached the toe board, close the bleed screw before returning pedal to release position. Repeat this procedure until soild fluid, free from bubbles, comes from the bleed screw. Check the master cylinder frequently to insure an ample supply of fluid.
<O
Using this method, bleed No.1 and No.2 bleed screws on the Hydrovac and then proceed to the vehicle wheel cylinders. Then start with the wheel cylinder farthest from the master cyl and work your way to the wheel that's closest; typically Rr, Lr, Rf, Lf.
Old 10-08-2009, 11:54 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Thanks for posting this!
Old 10-09-2009, 09:55 PM
Larry_the_handyman's Avatar
Larry_the_handyman
Larry_the_handyman is offline
Does a vacuum pump/one man bleeder work with this contraption? I'm too lazy to get someone else to help.
Old 10-12-2009, 07:26 AM
3414's Avatar
3414
3414 is offline
I have never been able to properly bleed a systen with a remote booster with a vacuum bleeder.
If you have no pedal at all, I suggest doing a part by part test -
1 - remove brake line at master cyl and plug master cyl. If pedal is good, master cyl is good.
2 - Reconnect master cyl, ans disconnect the lines to all wheel cylinders from remote booster, plug remote booster. Bleed remote booster and then check pedal, if it is good remote booster is good.
3 - Reconnect front brakes, plug/cap lines to rear brakes. Bleed front brakes. Check pedal, if it is good, front brakes are OK.
4 - Reconnect rear brakes, and bleed them. For dual cylinder brakes I have found that you need a helper who can really apply the brakes hard. Make sure you open the bleeders as much as possible to get a strong stream. If the wheel cylinders are good, this should result in a good pedal. You may then want to rebleed the fronts to make sure all air is removed.
If you start with a "pedal to the floor" and a simple bleed has no effect, I have found that the above procedure and a helper is the only way to go. Good luck.
The following 2 users liked this post by 3414:
Old 10-12-2009, 11:25 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is offline
sweet! this is going to help me bleed the brakes on the bronco/f800 as soon as i get it back from storage!! i was wondering what the procedure was going to be.
Old 11-30-2011, 03:20 PM
SGT DuckButter's Avatar
SGT DuckButter
SGT DuckButter is offline
Really, Thank You for posting this.
Old 12-25-2016, 11:20 AM
tonymontanna1983's Avatar
tonymontanna1983
tonymontanna1983 is offline
This post is a life saver, thanks!!!!!!!
Old 12-25-2016, 01:04 PM
NoFrod's Avatar
NoFrod
NoFrod is offline
Pressure Bleeder / Not Vacuum Bleeder
Pressure bleeder is the appropriate tool.
Old 10-14-2019, 08:56 PM
tcarroll47's Avatar
tcarroll47
tcarroll47 is offline
thanks for this post working on a 1975 f600 with no brakes ill give this a try
Old 10-15-2019, 08:43 PM
DBGrif91's Avatar
DBGrif91
DBGrif91 is online now
If any of the wheel cylinders are not fully horizontally mounted (at an angle or fully vertical), I recently discovered that backing off the brake shoes helps eliminate the air pockets that form above the bleeder screws.
Just be cautious in how far you back them off (if star wheels - cam adjusters can be backed off all the way) - I backed one off too much and it started leaking when I started bleeding them. I would guess only backing them off enough to remove the drum is good, but I haven’t had the chance to experiment.
Old 10-15-2019, 10:01 PM
tcarroll47's Avatar
tcarroll47
thanks for the advice ill back mine off before i start this type system is all new to me will a vacuum bleeder do any good on this type brake system
Old 10-15-2019, 11:13 PM
DBGrif91's Avatar
DBGrif91
I don’t know for sure, but I’m guessing the lines are just too large and too long for a vacuum bleeder to be effective. Vacuum bleeding depends on moving the right amount of air volume for the right amount of time and most commercially available vac bleeder kits just aren’t capable of doing it. I suppose if you have an electric vac pump it might work, but the problem with that is you’ll never see air stop moving thru the line because it’ll siphon air from around the threads of the bleeder screw.
If you don’t have a pressure bleeder, I’d recommend gravity bleeding to start, just to get some fluid in the lines, then manual bleeding with a helper to make sure it’s all purged.
Old 10-16-2019, 02:01 PM
iceberg210's Avatar
iceberg210
iceberg210 is offline
Does anyone know the part number for the hose from the master cylinder on this set up? Need to replace mine as it has a compression fitting that shouldn't be there in it.
Thanks
Erik
Old 10-16-2019, 04:25 PM
tcarroll47's Avatar
tcarroll47
thanks DBGrif91 ill check on a pressure bleeder and do a gravity bleed first and go from there thanks again
Old 11-18-2019, 02:31 PM
iceberg210's Avatar
iceberg210
I've got a 78 f600 and the bleeders look different than the standard 7/16 " ones I grabbed at the parts store, is there a particular name for them? having a hard time finding them
thanks
Papawheelie
30
02-23-2017 05:14 AM
jmtbiggin
Large Truck
11-13-2016 04:16 PM
myakkacracka
13
06-16-2016 11:33 AM
Elmo154
Vehicles for Sale
04-19-2016 02:58 PM
AL`
02-17-2016 01:54 PM
Quick Reply: Bleeding a Hydrovac Brake System
