2003 6.0L Tow/Haul Lights Flashes
Old 10-05-2009, 01:02 PM
Freedom0115's Avatar
Freedom0115
Freedom0115 is offline
I have a 2003 F350 Crew cab DRW 6.0L Diesel. I have been experiencing problems with the trans all summer. It seems the tow/haul light starts flashing and at that point the trans starts shifting irregularly. Such as starting off from a dead stop, the trans will be in 2nd gear or at higher highway speeds it doesn't down shift as it should when calling for more acceration... All of this only gets worse if I tow my boat. So far we have changed out the shift solinoids with still no luck..
Can anyone help?
Old 10-05-2009, 01:54 PM
l-m tech's Avatar
l-m tech
l-m tech is offline
what code are you getting
Old 10-05-2009, 02:28 PM
Freedom0115
Just the " Keep Alive Memory" which I had reset at the dealer.
My friend from the dealership is bringing the Ford scan tool over tonight and we are going to check it again.
Old 10-05-2009, 05:18 PM
dcaddi2's Avatar
dcaddi2
dcaddi2 is offline
With the tow/haul light flashing, you'll have tranny related DTC, that sure will lead you to the source of the problem....I'm sure the Ford scan tool will pick it up.
Old 10-05-2009, 07:37 PM
ljutic ss's Avatar
ljutic ss
ljutic ss is offline
I had a similar problem with mine in the spring, my fix was the TFT sensor in the trans was bad. It would run fine for a mile or 2 then the trans temp gauge on the dash would bury hot and I would start getting the weird shifts. If this is your problem, it's a very easy fix.
Old 11-02-2009, 06:51 PM
Freedom0115
Well the trans codes are as follows... Hope someone can help me here..
P2703
P0730
Old 11-02-2009, 06:52 PM
Freedom0115
Code P2703 and P0730
Old 11-02-2009, 10:36 PM
topdrive's Avatar
topdrive
topdrive is offline
p2703 -Transmission friction element d apply time range/performance
p0730-incorrect gear ratio
i dont no if that helps im lost when it comes to trannys good luck
Old 11-03-2009, 03:45 AM
dcaddi2's Avatar
dcaddi2
dcaddi2 is offline
Now, this is not good. Even though these codes could be related to a faulty shifting solenoid, but a solenoid usually have it's "own" DTC.
I've had symptoms as you have, and I've had gear ratio and friction element codes, and I ended up rebuilding my tranny......
Old 11-03-2009, 01:42 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
Freedom....are you running a tuner on the truck?
Old 11-03-2009, 02:14 PM
Freedom0115
I was running a Bully Dog Power PUP.... since this problem has occured I removed everything and put it back to stock.... The programer only elevated the symptoms even worse..
Old 11-03-2009, 03:26 PM
firemanpat29's Avatar
firemanpat29
firemanpat29 is offline
transmission. (transmission is shot!!!!!!!!)
Old 11-03-2009, 04:50 PM
dcaddi2's Avatar
dcaddi2
dcaddi2 is offline
What do you mean it shifts irregularly? Is it slipping?
I understand that it gets stuck in 3rd gear at a stop. Do you have any symptoms in reverse? I'm asking, because the week part of the 5r110 transmission is the direct clutch, and if you have a problem with that, it will get stuck in 3rd gear sometimes, you also will notice slipping between 3-5th gear, but it also will act weird in reverse ( delayed engage, shaking ).
Anyways, the bottom line is, you got friction DTC-s, and you mentioned that you drove the truck like that all summer long - and towing a boat, so I believe that you will facing a tranny rebuild. If you like the challenge, you could do it yourself, but I'll tell you by experience, that it's one of the hardest jobs on the 6.0 - mostly because dropping and reinstalling that heavy beast. But it's still doable, and if you decide not paying about $2500-3500 on labor I highly recommend getting a torqueshift rebuild manual - you can find'em on ebay.
For the time being you could try replacing the fluid, but i doubt that will help.
Old 03-10-2014, 07:29 AM
03powerstrokefl's Avatar
03powerstrokefl
03powerstrokefl is offline
P2703
P0730
My truck is doing the same thing and still haven't figured it out. But I replaced the trans temp sensor and it didn't help out.
Old 03-10-2014, 08:12 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
What codes did you have stored?
Mr Jake
1999 to 2016 Super Duty
16
11-27-2019 04:01 PM
tjustice
02-02-2016 03:40 PM
AKMKGUY
01-04-2016 11:14 AM
titusf350
05-12-2015 12:05 PM
gharris54
07-11-2014 04:19 PM
Quick Reply: 2003 6.0L Tow/Haul Lights Flashes
