1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011 Ford Super Duty 6.2-Litre V-8 Gas Engine article
Old 10-01-2009, 08:24 PM
Ford-Trucks Editors's Avatar
Ford-Trucks Editors
Ford-Trucks Editors is offline
Host
Hey guys,
The 2011 Super Duty is sporting an efficient 6.2L dual equal V8. Sounds cool; sounds like Ford is taking its trucks into a good place for the future. What do you guys think? Do you think the power will be there? Are you impressed by all of the innovations under the hood and in the cab?
Find the Articles here (scroll down to Latest Articles to find the photos): Ford Truck Enthusiasts .: Articles
The News can be found here: 2009 .: News
Tons of engine discussion threads can be found here: Ford Truck Enthusiasts Forums - Threads Tagged with engine
Thanks
Old 10-01-2009, 08:36 PM
LSchicago2's Avatar
LSchicago2
LSchicago2 is offline
I hope they can tune it for more torque. Torque is more important on the Super Duty trucks than horsepower.
Old 10-01-2009, 10:28 PM
Tom's Avatar
Tom
Tom is offline
Awww, man! Not this again!
Torque and horsepower go hand in hand, there is no one without the other. High torque at a certain RPM means high horsepower at that RPM.
What's important in a truck motor is a consistent torque curve throughout the RPM range; preferably one that has a strong low end and increases as the engine revs.
Horsepower is a measure of torque at speed. Torque without RPMs is useless, as it makes 0 horsepower. A mythical 1,000,000 ft-lb engine spinning at 1 RPM makes 190 HP. A 4.0L V6 out of a Ranger will pull harder than that 1,000,000 ft-lbs.
I think the 6.2 could be really great. I'm excited to see what the new VCT system can do for an engine that large. I've heard it will be more efficient than the outgoing 5.4L V8, and with over 400 ft-lbs and HP it should be an amazing engine. Far superior to the GM and Dodge gasoline HD offerings!
Old 10-02-2009, 02:47 AM
Pocono Super Duty's Avatar
Pocono Super Duty
Pocono Super Duty is offline
According to the article, the V-10 will still be available in the Super Duty. I though they were dropping the V-10? This could be good news.
Old 10-02-2009, 07:51 AM
edjunior's Avatar
edjunior
edjunior is offline
I saw that too, but it didn't look like they were changing anything in it. Not even the transmission. The new 6.2 gets the new 6 speed, but the V-10 stays with the older 5 speed.
Old 10-02-2009, 08:57 AM
Tom's Avatar
Tom
Tom is offline
Yes, it will be available in the Super Duty. Just not in the pickup trucks! The V10/5R110 will only be available in the F-450 and F-550 chassis/cabs.
Old 10-02-2009, 09:08 AM
LSchicago2's Avatar
LSchicago2
Since I only buy F450/550 C/C's it is good for me. I need the torque more than horsepower, because I use them as tow trucks. I don't want to spin the engine to 6000 RPM to merge on the highway. While I think the 6.2 is a great engine, it is not a great replacement for the fat torque curve of the v10. Hopefully they come out with the 7 liter version, that would be a suitable replacement for the V10 on the cab chassis.
Old 10-02-2009, 11:04 AM
Tom's Avatar
Tom
Tom is offline
I agree, a nice, flat torque curve is what we need to have. But just because it has a high peak torque number doesn't say anything about low end torque, that's kind of what I was getting at.
For example, it could generate 455 ft-lbs @ 5,000 RPMs, and it would be a lousy truck motor if it had half that at low RPMs! 455 @ 1500 would be amazing.
High low end torque numbers mean it has high low end horsepower, since they do go hand in hand. A high peak power output normally means it has lots of torque at high RPMs.
For example, a great motor would be something like 410 HP @ 5,000 RPM and 455 ft-lbs @2,000 RPMs. Such a motor would be pounding out 430 ft-lbs at 5,000 RPMs, with peak torque at 2,000, which would provide a nice, flat torque curve all the way up to redline.
Such a motor, IMHO would be much better than the current 3V V10.
Old 10-02-2009, 11:26 AM
akford351's Avatar
akford351
akford351 is offline
I'm excited about the new 6.2... should perform well.
Old 10-11-2009, 09:44 PM
socalpsdowner08's Avatar
socalpsdowner08
socalpsdowner08 is offline
Well the end of the year 2011 im gonna get one.
Old 03-29-2010, 12:57 PM
pony's Avatar
pony
pony is offline
I really hope the new V8 is a good one. After the the Tritons' spark plug issues I assure you I'll be keeping an eye on the new one for any bogey men showing up.
Old 05-19-2010, 11:12 AM
LADYHAWK's Avatar
LADYHAWK
LADYHAWK is offline
Help, does anyone know where I can order the power steering hoses for the 2011 Ford SD, for both gas and diesel?
Old 05-19-2010, 11:26 AM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
You can try Ed from www.partsguyed.com, a sponsor here. Don't know if they would be avail just yet.
why do you need them?
Old 05-19-2010, 01:42 PM
LADYHAWK's Avatar
LADYHAWK
LADYHAWK is offline
what to put a hydraulic winch on, but need the fittings , since they are different from the 2010.
BigF350
98
07-15-2011 11:01 AM
Ford-Trucks Editors
62
03-02-2011 02:38 PM
BigF350
6.7L Power Stroke Diesel
159
02-01-2011 05:10 AM
Ford-Trucks Editors
Fifth Wheel & Gooseneck RV Towing
04-15-2010 01:21 PM
Ford-Trucks Editors
30
12-15-2009 07:00 PM
Quick Reply: 2011 Ford Super Duty 6.2-Litre V-8 Gas Engine article
