1963 Ford C700. What size engine?
Old 09-30-2009, 09:59 PM
hinton08's Avatar
hinton08
hinton08 is offline
Exclamation 1963 Ford C700. What size engine?
I know it is in the Y-Block family because of the two bolts on the end of the valve covers. But I'm not sure what size it is for sure. The VIN # is C70NU342242. I need to know what size it is asap. I'm tearing down the engine and replacing the head gaskets. The owner of the truck thought it was a 330 V8 but I didn't think the 330 V8 was used until 1964. Let me know asap please! Thanks!
Old 10-01-2009, 10:43 AM
dusty64f100's Avatar
dusty64f100
dusty64f100 is offline
Try this page
TECHNICAL
A Y block should have a distributor in the back and an air gap manifold
I would suggest you measure the bore and stroke after you pull the heads off and that'll tell you exactly the cu in.
Are you sure a 330 isn't an FE, such as the 361/391 industrial engines?
Old 10-01-2009, 11:31 AM
hinton08's Avatar
hinton08
hinton08 is offline
Well I assumed it is in the Y Block family because of the two bolts at the end of the valve covers, I thought that was specific to that type engine?
Old 10-01-2009, 01:41 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Welcome to FTE
C70 = C700 Tilt Cab
N = 302 / This engine (and the larger 332) were derived from the 1955 Lincoln Y block.
This is not the same engine family as 239/256/272/292/312 Y blocks. The engine parts do not interchange!
U = Louisville KY Assembly Plant
342242 = 1963, assembled in October 1962.
The last year for these Lincoln based Y blocks was 1963. FT engines (330 2V M/D; 330 2V H/D; 361 2V & 391 4V) were introduced in 1964.
Since the last year for these engines was 1963, you may have trouble finding head gaskets.
C3TZ6051C .. Head Gasket / Obsolete / Fits 1957/63 302/332.
LUM'S FORD in Albemarle NC has TWO = 800-951-1122.
BOWMAN FORD SALES in Bowman ND has EIGHT = 701-523-3257.
GREEN SALES CO. in Cincinnati OH has 29 = 800-543-4959.
C3TZ6079C .. Valve Grind Gasket Set / Obsolete
Includes: head gaskets, valve seals, valve cover gaskets, intake & exhaust manifold gaskets, valley pan gasket, t/stat gasket.
Fits: 1963 302/332. 1957/62's use different valve cover gaskets.
BOWMAN FORD SALES has ONE.
KLIMESH MOTOR SALES in Calmar IA has TWO = 563-562-3241.
AITKEN MOTOR CO. in Aitken MN has ONE = 218-927-2169.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 800-546-7278.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
GREEN SALES CO. has TEN.
Old 10-01-2009, 02:18 PM
hinton08's Avatar
hinton08
hinton08 is offline
Yeah I finally found out today also that it was a 302. Took it to the machine shop and we matched the gaskets up. And you are DEFINITELY right about having trouble finding the head gaskets. None of the parts stores neither have them or can even get them!
Old 10-01-2009, 02:21 PM
NumberDummy
I found the head gaskets and the valve grind gasket set. See my post above.
The Ford part numbers are typed in blue.
Old 10-01-2009, 05:30 PM
hinton08's Avatar
hinton08
hinton08 is offline
Yeah I ordered them from Green. It was $39 plus shipping for the valve grinding set and for 2 oil tubes that lube the rocker shafts. I was AMAZED at how cheap it was. I was expecting close to $100 for everything since its a rare year/engine combo. Thanks again everyone! Now the next thing I should ask, is what is the head bolt tightening sequence and any other specs I need for reassembly?
Old 10-01-2009, 06:37 PM
hinton08's Avatar
hinton08
hinton08 is offline
I also need to know the proper sequence for adjusting the valves on this engine also
Old 04-27-2010, 12:17 PM
CALIF-COWBOY's Avatar
CALIF-COWBOY
CALIF-COWBOY is offline
ITS A 361 OR A 391 industrial maybe made in canada We have a 1972 24000gvw and had to have it rebuilt
do you know where to get parts for the hyd. clutch?
Old 04-27-2010, 12:27 PM
CALIF-COWBOY
so the small block 302 is not the same as ybloock 302 ?
Old 04-27-2010, 02:13 PM
NumberDummy
Originally Posted by CALIF-COWBOY
ITS A 361 OR A 391 industrial maybe made in canada.We have a 1972 24000gvw and had to have it rebuilt
This thread you dug up is 18 months old. The engine in the OP's 1963 C700 is a Lincoln based Y block 302, not a 361 or 391 FT engine.
FT engines were not available until 1964. The Lincoln based 302/332 Y blocks were canceled after the 1963 model run ended.
The Y block 302 is an entirely different engine than the "small block" 302, which was introduced in 1968.
Please start a new thread for your hydraulic clutch question, and be specific as to the year, series, what parts you need for it.
tylstruck
51
05-27-2023 04:55 AM
JensHansen
12-06-2016 03:34 PM
ShockFox395
10-27-2016 04:15 PM
akaFrankCastle
16
03-08-2016 04:51 PM
oldfatandtired
Large Truck
07-23-2011 12:15 PM
Quick Reply: 1963 Ford C700. What size engine?
