Fuel Injection Control Module
Old 09-30-2009, 06:19 PM
bezzell's Avatar
bezzell
bezzell is offline
I have a 2004 F250 6.0l. I had to take it in to the ford dealership to get diagnosed and they said that my ficm was fried. My truck is not displaying any codes on the display. Could the problem also be maybe chafing on the wiring harness? I been doing some research and apparently alot of time the ficm is misdiagnosed. I would think that i would of at least got some kind of error code or check engine light. What do you think?
Old 09-30-2009, 06:23 PM
adambomb's Avatar
adambomb
adambomb is offline
i'm not 100% sure but when my FICM went out last year i don't think i had any codes. hopefully others will know forsure
Old 09-30-2009, 06:33 PM
bezzell's Avatar
bezzell
bezzell is offline
Ok thanks, did you have it replaced at a dealership or do it yourself?
Old 09-30-2009, 06:34 PM
adambomb's Avatar
adambomb
adambomb is offline
yeah dealership out of warranty.
koboss1's Avatar
koboss1
koboss1 is offline
I went through about 3 ficms with my 6.0 and it always happened after my batteries died... changed batteries after that and happened again and truck died.. turned out it was the alternator was bad kicking in and out not charging right... anway the ficm cant take low voltage fries them every time.
Old 09-30-2009, 06:35 PM
bezzell's Avatar
bezzell
bezzell is offline
ok that may be it then cause i had to replace the batteries not to long ago
adambomb's Avatar
adambomb
adambomb is offline
very true. that's a bummer you burned up 3. wow lot of money. good batteries are key!
Old 09-30-2009, 06:36 PM
bezzell's Avatar
bezzell
bezzell is offline
The dealership quoted me at 1300 to replace it
Old 09-30-2009, 06:37 PM
adambomb's Avatar
adambomb
adambomb is offline
that's about what i paid
bezzell's Avatar
bezzell
bezzell is offline
I found some rebuilt ones on ebay for 495, thought about doing it myself
Old 09-30-2009, 06:41 PM
koboss1's Avatar
koboss1
koboss1 is offline
dont forget... it wasnt that i had bad batteries... they checked them always after they had the hood up all day or sometimes 2, then batteries tested fine..
IT WAS the alternator that was faulty the whole time ... sometimes it would charge and then quit leving my bateries on there own then when i go to start.. usually in the winter .. click..click then i would curse like a sailor and in the shop again till it was figured aternator
good luck to all
Old 10-01-2009, 06:55 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke
MoyockPowerstroke is offline
When my FICM went....it threw several DTCs...basically each injector was effected (with its own DTC), and a couple of general DTCs as well. But, it did occur just after diagnosing bad batteries and replacing them. I often wonder why I shouldn't just plug her in each night to a battery tender.
Old 10-01-2009, 11:13 PM
Racecarhauler's Avatar
Racecarhauler
Racecarhauler is offline
Spare/Loaner FICM??
Does anyone on here have or know anyone that has a spare "loaner" FICM that I could use to see if that's what's wrong with my truck?
I know it's a lot to ask but I'm a trustworthy individual and certainly wouldn't hose anyone on here (unless she was real good-lookin' ) - I pulled my EGR valve today to clean it and sprayed a bunch of carb. cleaner down in the intake, started the truck without the EGR valve in, ran it up in the RPMS a few times to blow the gunk out and it shut off, just plain shut off.
I explained on another thread that I have been troubleshooting an issue whereas I am low on power here lately, not real low but a noticeable loss. I can still tow my 8,000lb race trailer, etc.
Well, now it's DEAD, won't start at all, can hear the fuel pump running when you turn the key on like normal, fuel in the filter bowl, etc.
If anyone has any suggestions I'm listening - I have a race trip next Friday and I'm not too close to a dealership...nor would I have the serious $$$$$$$$ to pay them to change a FICM out on a whim.
I'd like to know it's what is causing the no-start condition before shelling out the big bucks.
Old 10-03-2009, 09:05 PM
nitrogen's Avatar
nitrogen
nitrogen is online now
they don't always run without the egr valve istalled, my 05 will if its hot, but not if its cool. Try installing the valve and see what happens
Old 10-03-2009, 09:23 PM
plowin4u's Avatar
plowin4u
plowin4u is offline
You just can't install a ficm and start it up, each ficm needs to be reflashed or reprogrammed to each specific vehicle.
Quick Reply: Fuel Injection Control Module
