95 f150 no spark
95 f150 no spark
I just bought this 95 f150, 4.9l, 5 sp
it has no spark
I was using a haynes manual to troubleshoot
I had the ICM tested and it's ok
it said to pull the plug from the ign control module and check the voltages on pins 2 and 3, 11.5 volts,in run position, then disconnect S wire and check voltage on pin 4, I have no voltage on pin 4 in run or start position.
I also put a test light on the white coil wire and get a light, it is supposed to flash when trying to start the engine, it does not flash, just stays on constant.
I should also mention, it looks as if someone has put in a new distributer, coil, ICM, plugs, wires, the works. the only thing not new is the ballast resistor or whatever the little round thing is under the coil(looks like a fat AA battery).
thanks for the help, I'm really lost here.
it has no spark
jrb412
11-05-2010 03:15 PM
shouldagotablazer
1978 - 1996 Big Bronco
48
03-01-2007 03:53 AM
acc7484
Electrical Systems/Wiring
08-11-2005 10:22 AM
