5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
New engines
Old 09-24-2009, 03:26 PM
MM1281's Avatar
MM1281
MM1281 is offline
New engines
When and how much? We know the 5.0 is coming and possibly the boss 6.2. What about the TT 3.5 and what about the 3.7 Cyclone being the base engine? The wait is killing me and I want more info.
I bet the 6.2 will only be available on top end models which sucks Ford. I will remind you that a 5.7 is available in every single Tundra down to a RCSB 4x2.
Does anybody have any info on the new engines? This is going to be a major change and a step in the right direction imo for Ford. The Ford engines are just weak compared to the top power trains from the competitors and a lot of people have raised hell about it. Some are perfectly happy of course but I dont drink the blue koolaid and I want results.
There is no such thing as too much power, lighitng that is too bright, or a gas tank that is too big.
Old 09-24-2009, 05:46 PM
Hybris's Avatar
Hybris
Hybris is offline
With what I have read point to ford not having a EcoBoost 5.0L V8 I'm beginning to question my praise of the EcoBoost idea. A full size truck should have a V8 minimum anything smaller and it lose some of its full size-ness. Now the Ranger guys are going to go nuts over a twin turbo V6 for them so maybe its time to look at a new ranger?
Old 09-24-2009, 06:00 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
The thought that anything less than a v8 is a waste is outdated thinking.....who thought camaros could put out 300 hp in a v6?? Times and engines are changing....we can make as much power in a v6 as the last generations biggest v8's today......sure theres a place for v8's....but to say a turbo'd v6 will make it loose full size status is outdated thinking
Old 09-24-2009, 06:56 PM
Hybris's Avatar
Hybris
Hybris is offline
In that case Ford had better do well with the TT V6 in order reverse the stigma of no less than a V8 because honestly I think that what a lot of people will think until proven wrong.
Old 09-24-2009, 07:33 PM
ClearlyBC's Avatar
ClearlyBC
ClearlyBC is offline
Even if the Horsepower is there, the bigger question for a truck is how much torque does it produce, and is it in a useable range of the powerband for towing?
A F450 diesel only makes 325 Horsepower, but a lot of torque, and where it can be utilized.
Old 09-24-2009, 07:38 PM
ChargersFanInCO's Avatar
ChargersFanInCO
ChargersFanInCO is offline
Yep, horsepower sells trucks (for some stupid reason or other)...torque moves them.
Old 09-24-2009, 08:25 PM
stang3O2's Avatar
stang3O2
stang3O2 is offline
Well stated.....heck, the new Taurus SHO V6 puts out like 370HP....but I prob wouldnt plan on towing with it! haha
Old 09-24-2009, 08:58 PM
Ryan50hrl's Avatar
Ryan50hrl
And it puts out 350 ft-lbs of torque....how much did the 2v 5.4's put out????...i'd bet you'd be pretty damn surprised about how well it tows...
Old 09-24-2009, 09:06 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,222 Likes on 804 Posts
This engine is actually borrowed form the Caddy CTS. It produces 304 HP and 273 ft lbs Tq. It's no doubt a very bad *** engine.
I have to agree with the others. A V-6 is a great application as long as your not pushing huge amounts of snow or doing some of the neavier work that a V-8 gasser or smoker is expected to do.
Tim
Old 09-24-2009, 10:17 PM
tlk50's Avatar
tlk50
tlk50 is offline
New Boss 351W
Read today that Ford will be delivering to the market the new Boss 351W the last quarter of 2009. The article said it is a four bolt main with thicker cylinder walls. They're supposed to be a 2.75" main journal diameter instead of 3.0" (same as 351 C). Just wondering if anyone has an update on these.
Tim
Old 09-24-2009, 10:47 PM
irishammer's Avatar
irishammer
irishammer is offline
The Ecoboost can make all the HP and TQ it wants....reliability will be the real issue. A couple thousand pound car is quite a bit different than a 1/2 ton pulling trailers. And if/once it breaks get ready to lighten the wallet!!!
Old 09-24-2009, 11:33 PM
slcdzl's Avatar
slcdzl
slcdzl is offline
Here's a snippet from a Ford press release:
EcoBoost for truck applications joins F-150 lineup
Joining the lineup for the F-150 in 2010 is a version of Ford's EcoBoost engine, specially engineered and optimized for truck applications.
This new engine builds off the strengths of the EcoBoost system, which include:
Peak torque that begins at a low engine speed and continues across a wide rpm band, making it ideally suited for trailer towing and other truck applications.
Direct fuel injection, which uses high-pressure fuel injectors to spray a fine mist of fuel directly into each cylinder. This precisely controlled fuel delivery improves the engine's transient response, contributes to improved fuel economy and enables improved emissions, particularly at cold start.
Turbocharging for increased boost and power; precise controls mean instant spool up.
20 percent better fuel economy and reduced CO2 emissions compared to a larger naturally aspirated engine.
It should be interesting to see it perform in real world applications compared to the V8's. Ford does a whole heck of a lot of testing on stuff, so I'm pretty confident it will be a good engine. I guess we have a while until we can say for sure. Supposed to be late 2010.
Old 09-25-2009, 08:30 AM
tvsjr's Avatar
tvsjr
tvsjr is offline
Err, really? You should have owned my 2005 F350 6.0PSD - three head/head gasket/turbo replacements in 85K.
The new motors are one reason I bought my 09 - I'm very happy with (and very comfortable with) the tried and true Modular 5.4. I don't want another "young" motor... once bitten, twice shy.
Old 09-25-2009, 03:13 PM
stang3O2's Avatar
stang3O2
stang3O2 is offline
Agree completely 100%!!! Just meaning the truck and its V8, even the 2v with 260hp and 350ft/lbs its meant for towing. I did read the SHO, it produces 350ft/lbs at as low as 1500rpm all the way up to like 6000rpm, pretty awesome. Ill stick w my truck for towing though. But id love a 4 door V6 that runs a 14sec quarter mile!
Old 09-25-2009, 03:19 PM
MM1281's Avatar
MM1281
MM1281 is offline
Uh, one just went 13.17 with just a tune.
http://www.youtube.com/watch?v=zXCfobhZl-0
Thats hauling the mail for a car that heavy. Imagine this engine in a Mustang.
Quick Reply: New engines
