need help decoding vin on 61 econoline
Old 09-16-2009, 05:43 PM
chris tatro's Avatar
chris tatro
chris tatro is offline
i recently bought a 1961 econoline van for 200 bucks. need help decoding the vin
E10SH191740
WB 090
COLOR A
MODEL E104
DATE (IS BLANK?)
TRANS A
AXLE 02
79HP@4000RPM
any help is greatly appreciated
my email is cdtatro1979@aol.com thanks chris
Old 09-18-2009, 09:22 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
E10SH191740
WB 090
COLOR A
MODEL E104 ??
DATE (IS BLANK?)
TRANS A
AXLE 02
79HP@4000RPM
Welcome to FTE
E10 = E100
S = 144 1V 1-6
H = Lorain OH Assembly Plant
191740 = 1961, assembled July 1961.
90" Wheelbase
A = Raven Black
E104 = Incorrect, should be E140 = Econoline Van **
A = Ford 3 Speed Light Duty Manual Transmission
02 = Ford 7" Rear Axle / 4.00-1 / non Limited Slip / 2300 lb. Rear Axle Capacity.
79 net HP @ 4,000 RPM
** E104 is a pickup. If the MODEL code does show E104, the left door has been changed, which means some/all of this info is in-correct.
What happened was: The original left door was damaged, and replaced with a used door from a pickup.
When this occured, whoever did this...forget to install the original Warranty Plate on the replaced door.
roadbag
Idaho Chapter
01-11-2017 08:40 AM
Tony Paar
11-21-2016 08:40 PM
urbandale
03-24-2013 07:20 PM
getusome
3.8 & 4.2L V6
01-05-2009 09:41 PM
mm9093
1978 - 1996 Big Bronco
07-02-2004 02:29 PM
Quick Reply: need help decoding vin on 61 econoline
