Problem with turbo - F250 2006 Diesel
Old 09-20-2012, 03:43 PM
C_H_M's Avatar
C_H_M
C_H_M is offline
I just unplugged it as outlined in the Tech Folder on this site.
Still researching if I need to do any tuning etc... based on how I use it.
About 100 miles since the disconnect, no CEL or DTCs.
Old 09-20-2012, 05:43 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Originally Posted by C_H_M
First of all, many thanks to all the fine folks on this board that provide so much valuable information. I have been reading (there is a lot to read) as much as I can about the 6.0 and how to maintain and improve it.
Update on VGT:
Problem may be solved. Code was "turbo underboost". Dealer fix was replace the VGT with new improved version that does not rust. $2500. I was reading many of the issues on this forum and yesterday I decided to try a EGR disconnect. Wow! I have a new truck.
Prior to disconnect the turbo psi would only boost if I went full throttle and then it took 4.5 seconds to engage. The power always felt like a snail in mud and fuel economy was 13.4 best possible.
After disconnect, the psi gauge shows some involvement at all speeds and bounces to 30 psi at full throttle with only a very slight delay. The truck is very responsive and calculated MPG is 15.4 at 65 mph. It seems like this diesel/vgt combo was designed and built to run this way, and that maybe the EGR setup was an after thought to meet epa standards. Anyway, I have a totally different truck right now, and time will tell if this is a permanent fix.
I hope it is ok that I did not post this in the rather massive EGR thread, as I thought it was applicable to this discussion.
One disclosure that may have affected the large prior and current performance differential is that I have 35 inch tires but the speedo and shift points were adjusted by the dealer.
New VGT $2500? WHAT?
Old 09-20-2012, 09:40 PM
Benchwrench's Avatar
Benchwrench
Benchwrench is offline
I think new VGT stands for; they installed a new turbo to the tune of 2500 bucks.
Old 09-21-2012, 11:34 AM
C_H_M's Avatar
C_H_M
C_H_M is offline
$2500 was the estimate for a new turbo. I declined and did the disconnect, and it seemed to take care of the problem with the turbo.
Old 09-21-2012, 03:02 PM
TexasA&M's Avatar
TexasA&M
TexasA&M is offline
If all you did was disconnect the EGR, you're going to have problems with your engine fan. I'm not sure how they are tied together, but they somehow share a signal. It's best to turn your EGR off with a tuner, which will allow proper functionality of the engine fan.
Old 09-21-2012, 05:13 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Agreed^^^^
Or do a Proper EGR Deleate kit
$$2500.00 for a Turbo is STRAIGHT UP THEFT
Old 09-21-2012, 05:26 PM
amdriven2liv
I would like to know what they did to prevent rust. Maybe vane sweep flash.
Old 09-21-2012, 06:18 PM
bismic's Avatar
bismic
bismic is offline
Received 2,484 Likes on 1,722 Posts
"A Revised Machined Recess Turbocharger (5c3z-6k682-ca) Designed Exclusively To Address Corrosion Related Turbocharger Performance Is Now Available In Service."
Old 09-22-2012, 12:12 PM
blowin_smoke_1977's Avatar
blowin_smoke_1977
blowin_smoke_1977 is offline
I, too, have a similar issue. After tearing the top end down and doing both complete head overhauls, new head gaskets, head studs, EGR delete and oil cooler update I am having the dreaded turbo overpressure issue while throwing the P0299 underpressure code. I completely cleaned and lubed the turbo when I had it out, so I didnt think that was the issue. But searching the P0299 issue I decided "What the hell" and tore it out again to be sure. What did I find when I pulled the turbo? Nothing. Vanes are perfect, unison ring slides like greased lightning, and the removal of the inspection plug revealed that everything was good. There was some oil in the housing that I figure is the result of serious overpressure because it originates from around the spindle shaft. BTW, should I rebuild the turbo and replace the seals at this point to prevent runaway or further damage? Anyway, I also took out the MAP sensor and it was caked up like hell. Sonic ceaning it now. Would that cause the VGT valve to act erratically, or be a slow/no respond? This thing has absolutely crappy throttle response right now, very little low end, very lackluster mid band, and top end.... forget it. Sounds like a broken gas main driving by though. And where is the EBP sensor on the `04 models? I want to pull it and check it too.
On a seperate issue it is also throwing code P0282 - Injector Circuit Low #8 Cylinder, and P1000 - Monitor Checks Not Complete. Pulling the #8 cylinder injector harness while running causes the #8 cylinder to drop, so I know the inject is working, at least to some degree.
Knucks
03-26-2017 06:52 AM
comadvan
08-17-2016 11:20 AM
Mcrafty1
06-06-2016 03:13 AM
Will104
06-17-2015 03:31 AM
Kstar9
07-15-2012 12:28 PM
Quick Reply: Problem with turbo - F250 2006 Diesel
