Bent finger on pressure plate
#33
#34
Ford or other supplier. Or maybe just Wal-mart in the plastic pack...
ARP 150-2201 Pressure Plate Bolts
#35
well heck now that i know the size i can go get some at home depot,5/16-18, 1/2 in. Hex Head, mine look allot different though, like they have built in flastwashers and smaller hex heads.
#36
The link I posted is generic, not researched as specific to your application. Look at the bolts. They have a shoulder on them. I doubt you can find bolts like that at HD. Even if they are grade 8s.
Best bet is Ford if you want to be certain.
The a-hole in me wants to suggest that since the bent pressure plate finger does not bother you, why would rounded bolts be a problem? Got Vice-grips?
#37
#40
#41
#42
So I'm reading this because i pulled my second engine ever on Monday (the first one was about an hour prior lol) and I had my tow truck slightly crooked, the boom and winch were square over the engine, but about half inch to the driver's side while pulling. I ended up slightly bending one finger on the pressure plate and have this same concern, I'm buying a new plate, but I want to mount this conversation tomorrow and see if it'll drive. Your pictures 'timed out?' Cus there no longer there. Could you maybe post another if you still have one? The finger I bent is no more then half the width out of square, is that alot? Or is that "bandaid-able" for a Brief, see if it runs test.
#43
brepei
09-30-2015 12:35 PM
53fordman1
09-29-2015 10:05 AM
