Cargo Door Rattle / How to Fix?
Old 09-07-2009, 10:01 PM
Forest's Avatar
Forest
Forest is offline
The right rear cargo door on my Ex rattles on rough roads (therefore, almost all the time). I discovered it was the right rear door because I was able to make it stop by jamming a bungee cord between the door and the glass hatch.
Can any one tell me how to repair this rattle without resorting to the "bungee jam"?
Old 09-07-2009, 10:23 PM
EXv10's Avatar
EXv10
EXv10 is offline
Put a little thicker weather stripping in. (From the hardware store)
Old 09-08-2009, 07:23 AM
gr8scott72's Avatar
gr8scott72
gr8scott72 is offline
Or just turn the radio up.
Old 09-08-2009, 08:17 AM
Forest's Avatar
Forest
Forest is offline
C'mon guys. Hasn't anyone else encountered and solved this problem?
Old 09-08-2009, 08:21 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
I've not had that issue on 3 Ex's....
but if adjusting the hinges and latch does not help,
maybe try the fix for the door seals?
the one where you put the tubing through the weatherstripping ?
Old 09-08-2009, 08:31 AM
myblkex's Avatar
myblkex
myblkex is offline
maybe putting some weatherstripping on the bottom part of the door so it props it up just enough when you close it... Just don't use the cheap styro-foam stuff because it'll just bunch up and peel off. See if you can find the hollow foam tube type that type that resembles the stuff around the door jambs. HD has a pretty good selection of that stuff... aside from that I don't know if there are any adjustments you can make to the hinges etc... I'll have to check mine next time .. good luck.
Old 09-08-2009, 09:43 AM
CanadianSmokie's Avatar
CanadianSmokie
CanadianSmokie is offline
I second the suggestion of renewing the existing seal with latex tubing or foam backer rod... it cured my passenger door rattles.
Old 09-08-2009, 11:35 PM
EFLBIKER's Avatar
EFLBIKER
EFLBIKER is offline
Wink Vaccum tube
7/16 or 5/16 vaccum tube @ local auto store. ~$.50/ft. Remove seal, have friend hold one end, pull straight and pull tube thru with a fish tape. It takes about 15mins. No more rattles
koalamazed
Aerostar
07-11-2017 09:00 PM
JohnMcHugh1
08-25-2007 07:32 PM
mahanson
09-08-2006 09:27 AM
roastdawgg
06-29-2005 06:43 PM
pihlboy
06-14-2005 02:21 PM
Quick Reply: Cargo Door Rattle / How to Fix?
