89 f150
Old 09-17-2009, 05:45 PM
subford's Avatar
subford
subford is offline
Code 33, is not a KOEO code.
ER 12 indicates that during Engine Running Self-Test, engine rpm could not be controlled within the Self-Test upper limit band.
ER 33 in Key On Engine Running indicates that the EVP sensor input did not change after the EVR solenoid was instructed by the processor to open the EGR valve. Because a Code 84 was not received in the Key On Engine Off Self-Test, it is known that the EVR solenoid functions electrically. It is also known that the EVP sensor is in the expected closed valve range because Code 32 and 34 were not received in either Key On Engine Off or Key On Engine Running Tests.
ER 13 indicates that during Engine Running Self-Test, engine rpm could not be controlled within the Self-Test lower limit band.
ER 25 indicates that the Knock Sensor (KS) signal to the processor was not sensed during the Dynamic Response Test after the ID code in Key On Engine Running Self-Test.
Looks like a bad Idle Air Bypass valve.
Here all the names of the same item:
•Idle Air Bypass
•Idle Air Control
•Idle Speed Control
•Throttle Bypass Air
•Idle Bypass
•Inlet Air Controller
•Inlet Air Bypass
•Intake Air Bypass
•Intake Air Control
Old 09-18-2009, 06:34 AM
enriched&beyound's Avatar
enriched&beyound
enriched&beyound is offline
Thumbs up
•Idle Air Bypass
•Idle Air Control
•Idle Speed Control
•Idle Bypass
•Inlet Air Bypass
•Intake Air Bypass
•Intake Air Control
Thanks appreciate your efforts!!....I'll pass along this new information.
we did clean the Idle Air Control (AIC), it was very gunked up, but the interior plunger was moving, just laden with carbon... but prior to the tune up he was experiencing a high idle, just not as high as it is now. To clean it we remove the AIC from the engine, then removed the solenoid from the AIC, sprayed it thoroughly with carb cleaner, let dry, then reattached the solenoid and returned it to the engine.
Is there a right or wrong way to reattaching the solenoid on the AIC?? the O-ring looked good, no cuts or anything. & the gasket to the upper intake was appeared good as well.
Secondly~ when reattaching the whole AIC to the engine, the solenoid faces towards the radiator yes???....that is the only way we can see that that can be installed incorrectly....pretty sure that is the way it came off.
thanks again for all the help
Old 09-18-2009, 08:52 AM
Ricache's Avatar
Ricache
Ricache is offline
Does FORD call the IAC by all of these names? Or is it just us types?
I knew there were 2 names but 9? WOW Almost sounds like we're getting into human body part naming here.
•Idle Air Bypass
•Idle Air Control
•Idle Speed Control
•Idle Bypass
•Inlet Air Bypass
•Intake Air Bypass
•Intake Air Control
/Ricache
Old 09-18-2009, 09:50 AM
enriched&beyound
UFFTA...dyslexia strikes .....replace all AIC with IAC...sorry for the cofusion
Old 09-19-2009, 07:01 AM
enriched&beyound
Iac
Ok they took "it" , the IAC, off and double checked a couple of things.
with it removed...looking at the ports to the intake....then turn the key on and could see the plunger move and return with turning the key off.
so they are second guessing which way the solenoid should point when installed on the intake.
does it , the solenoid of the IAC, point toward the rear of the engine or to the front???
they think it was on the toward the front
we tried a spare IAC from my ranger....wasn't sure if it was good or not. any-way....the port sizes are sizeably smaller from the ranger....but it did help bring down the RPM's on a idle a bit ...but still way to high. As before, as soon as you put it into gear (Auto) it drops RPM almost to normal....is this still the a IAC problem
Old 09-19-2009, 07:32 AM
subford's Avatar
subford
subford is offline
These codes say that the computer could not control the rpm of the engine.
When a computer can not control the RPM it is most of the time the IAC valve or the wiring from the computer to the IAC valve. That is what I was going by.
High RPM most of the time is caused by a vacuum leak. This vacuum leak could be anywhere from a bad brake booster, a bad vacuum hose going to any solenoid or part or a bad intake or throttle gasket.
Old 09-19-2009, 08:58 AM
enriched&beyound
well that what I was think'n ...more of a vacuum leak.
just was concerned if there was right and wrong way to reattach the IAC.
thanks again
Old 09-19-2009, 09:14 AM
subford's Avatar
subford
subford is offline
Her are three images of it:
Old 09-19-2009, 12:01 PM
enriched&beyound
Hey thanks!! the pix clear it up any q's that were present.
BTW...great Pix's !!!
Brandon Harrison
12-02-2012 01:07 PM
maxine
09-30-2012 01:46 AM
Ronvic
02-23-2012 08:09 AM
KARTRACER6
1997 - 2003 F150
04-29-2007 06:46 AM
BradysDad
11-30-2004 02:24 PM
Quick Reply: 89 f150
