No Power to fuel pumps
Old 09-01-2009, 08:44 AM
lopitt85's Avatar
lopitt85
lopitt85 is offline
'89 F250, 5.8L, dual tanks
I was having an issue with the fuel pumps not pumping fuel, but I could hear the high pressure pump (brand new), and both low pressure (in tank pumps running. Verified each one by getting under truck and listening to the tank. So in the process of checking each pump I was following a tip suggested here to disconnect the high pressure pump's wiring, so as to not run it while dry, and verify that the back pumps are not only running, but are also pumping. So I disconnected the harness to the high pressure pump, and pulled the supply line for the back tank and stuck it in a bucket to catch the fuel. When I turned the key foward to power the rear tank pump, I heard a pffft (like a fuse blowing) and there was a little bit of white smoke under the hood near the battery/starter relay.
Now I get no power to any of the fuel pumps. Car still has power everywhere else. I can crank the car and it will try to start, but obviously it wont because no fuel is being pumped. The car has power everywhere except to the pumps. Where do I look? Starter relay is fine (I assume), as I can crank the engine from the key. Does the Fuel pump relay tie into the starter relay? Would a problem with the starter relay affect power to the fuel pumps? Where is the fuel pump relay? I swear I cant find it. I checked the fuses under the dash and they are all fine. I dont know where to look.
Old 09-01-2009, 09:01 AM
Neptoess's Avatar
Neptoess
Neptoess is offline
power distribution box drivers side under the hood behind your air filter. bunch of fuses and relays. check your manual to see which one the fuel pump relay is
Old 09-01-2009, 09:10 AM
subford's Avatar
subford
subford is offline
Sounds like you had the wires to the high pressure pump shorted to ground.
What you did was burn open a fuse link "M" that comes off the battery side of the starter solenoid.
Just try pulling each one of the fuse links apart and the one that stretches is bad.
You do NOT have a "power distribution box drivers side under the hood behind your air filter".
Your fuel pump and EEC Power relays are in a row on the drivers fender.
Old 09-01-2009, 09:13 AM
subford's Avatar
subford
subford is offline
By the way here is a wiring diagram if you need it:
Old 09-01-2009, 09:48 AM
lopitt85's Avatar
lopitt85
lopitt85 is offline
Wow thanks for the quick responses. I think you are right. One of the fusible links is really stretchy. Do parts houses carry these or do I need to see a dealer or junkyard?
Thanks
lopitt85
Old 09-01-2009, 10:38 AM
subford's Avatar
subford
subford is offline
Just go to auto parts store and buy a roll of 20 GA fuse link wire and splice it in about 3 to 6 inches with butt connector and a ring terminal.
Old 09-01-2009, 12:06 PM
lopitt85's Avatar
lopitt85
lopitt85 is offline
Thanks. Repair done, power restored. Now I just have to drop the tanks and replace the pumps.
Old 09-01-2009, 08:11 PM
Neptoess's Avatar
Neptoess
Neptoess is offline
i have a box under my hood that is clearly labelled power distribution box. so does a buddy of mine with a 92 4.9L
Old 09-01-2009, 08:23 PM
subford's Avatar
subford
subford is offline
Yes you and your buddy do but the OP does not.
Old 09-01-2009, 08:24 PM
Neptoess's Avatar
Neptoess
Neptoess is offline
oh. they must have started it with the 92 model year then. sorry for my mixup
Old 09-01-2009, 08:54 PM
subford's Avatar
subford
subford is offline
Yes I think 1992 was the first year for the box.
Rhino99
Modular V10 (6.8l)
02-21-2016 06:11 PM
Critterhunter
1983 - 2012 Ranger & B-Series
06-17-2015 05:11 PM
bored&stroked
07-31-2006 01:18 PM
Traderjoe28
General Automotive Discussion
07-21-2006 03:33 PM
mattklionsky
1997 - 2003 F150
08-02-2001 11:00 PM
Quick Reply: No Power to fuel pumps
