97 F150/4X4/auto Cruise Control trouble shooting writup.
Old 08-29-2009, 10:12 PM
Thudpucker's Avatar
Thudpucker
Thudpucker is offline
My CC dont work. I went looking for some tech data. I found this one through Google, but it wont work on my truck, because My truck, built in 96, dont seem to have a Cruise Control light in the Dash! DRAT!
I'll share it anyway, maybe somebody will see what I'm missing and point me in the right direction. Or have a Tech sheet for my 97.
"Enter self-test diagnostics by ‘Press n’ hold’ the speed control OFF switch while turning the ignition key ON! Making sure the engine does not start and is not running.
The speed control indicator on the instrument panel will flash once to indicate the speed control module entered the diagnostic mode.
Five additional flashes at this point indicate a defective speed control servo.
Release the OFF switch.
Do this within five seconds after entering the diagnostics mode
Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
(If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.)
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
NOTE: There will be a slight delay when the last button is pressed and the lamp flashes.
A Speed control indicator lamp flash with the last button (SET/ACCEL) indicates that the static test passed.
If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
3 flashes - deactivator switch is open or circuit defective.
4 flashes - vehicle speed signal is out of range or circuit is defective
Immediately (.25 second delay) after the static test, the speed control servo does a dynamic test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position.
During the dynamic throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the throttle returns to the idle position.
try this and see if the speed control module has any codes in it.
Old 08-30-2009, 06:30 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Change the title to 00-03 since it doesn't apply to the 97 to 99. The cruise light int he cluster was added for the 2000 MY.
Check your deactivator switch and the recall harness fuse for continuity. The switch is the most common failure. If those are good, inspect the servo's electrical connector for corrosion or overheating.
Old 08-30-2009, 10:29 AM
Thudpucker's Avatar
Thudpucker
Well...I never realized it before now, but we dont have an edit button!
Thanks for straightening me out on that. If you can delete the post, go ahead because it might just alleviate some confusion.
Dick.
johndem
1999 to 2016 Super Duty
20
12-26-2022 08:01 PM
westcar360
10-19-2019 06:45 AM
jspringator
07-15-2017 08:51 PM
Matt M, PA
07-27-2014 06:48 AM
steve83
Computer Chips & Tuners
05-19-2003 05:50 PM
Quick Reply: 97 F150/4X4/auto Cruise Control trouble shooting writup.
