1978 - 1996 Big Bronco
how to tell if ball joints are bad?
Old 08-29-2009, 04:32 PM
hatchet's Avatar
hatchet
hatchet is offline
how do you tell if the ball joints are bad when your buying a used bronco?is there a way to tell by looking at them?
Old 08-29-2009, 05:14 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
Not really. If you can get a front wheel off the ground you can do the wiggle test. Otherwise there isn't much you can do with the weight of the truck on the suspension.
Old 08-29-2009, 05:55 PM
fordbroncodave's Avatar
fordbroncodave
fordbroncodave is offline
get someone inside and turn the steering wheel a little in both directions when the engine is off and keys in the ignition on position
Old 08-29-2009, 10:28 PM
hatchet's Avatar
hatchet
hatchet is offline
ok but how do I tell if there worn?how to you tell by looking at them?
Old 08-30-2009, 12:43 AM
greystreak92
You don't. Ball joints under the weight of the truck are almost impossible to determine their serviceability. If you are particularly concerned about a truck you are considering purchasing, ask the seller if you can raise the front wheels one at a time and check for play in them with the wheel wiggle test. An educated seller will either be happy to let you or immediately admit they are worn. An uneducated seller can be convinced that you won't buy it unless they let you check.
Old 09-11-2009, 04:06 PM
polky's Avatar
polky
polky is offline
You can't wiggle teat because thats your bearings your checking. Lift your truck and place a solid pipe under tire and lift up and down. Have someone looking at your ball joints if there is movement they are bad.
Old 09-11-2009, 11:34 PM
greystreak92
Not true. The wiggle test will reveal ball-joint issues if you know what you are doing. If you are testing for ball joint wear you need to grasp the wheel at 12 o'clock and 6 o'clock and rock it by pushing in at 12 o'clock and pulling out at 6 o'clock then reversing this maneuver. The pipe isn't necessary. If the balljoints are indeed bad, you will be able to affect enough movement and be able to tell. If you need the pipe to get them to move, its unlikely the ball joints are that badly worn.
I've done this test myself hundreds of times and can always get a definitive result. If you are really that concerned check the tread near the inboard shoulder for cupping as well. (Cupping is a wear pattern that causes the lugs of the tread to wear in a sawtooth pattern along the edges of the tread). While a bad bearing can cause minor cupping, ball joints are more often the culprit.
Old 09-12-2009, 07:42 AM
helirich's Avatar
helirich
helirich is offline
If the ball joints are really bad, you can see movement with the weight on the wheels. I recomend looking under the front while someone rocks the steering wheel. You can see alot. Here is a list.
The steering box could be loose. (on the frame)
The sector shaft could be loose. (bad steering box)
The pitman arm could be loose. (on the splines)
The drag link to pitman could be shot.
The drag link to right wheel could be shot. (tierod end)
The tierod end at the left wheel could be shot.
The tierod to draglink could be shot.
The balljoints can be loose.
The axle pivot mounts could be loose.
The wheel bearings can be loose.
In addition, you can look down from the top and see if the pitman arm moves imediately when the steering shaft is twisted. (play in the box)
All of these can be seen if you make sure you know what you are looking at and what it is moveing in relation to. One thing, the wheel bearings will not move (even if their shot) when the brakes are on or hanging up.
I assume you are worried about the balljoints because it is one of the more difficult things to repair on this list. If you are that worried, jack it up and do as Greystreak says. It will be much, much easier to see movement that way.
Old 09-13-2009, 03:03 PM
polky's Avatar
polky
polky is offline
if you can feel your ball-joints by wiggling your tire your joints are completely shot. as far as tire cupping if you have mud tires they will cup reguardless. i would check all that helirich noted.
Old 09-14-2009, 12:36 AM
hatchet's Avatar
hatchet
hatchet is offline
hey guys thanks for all the tips im had my buddy come along and the ball joints were bad.the guy didnt want to the lower the price cause of the bad ball joints so my search for a bronco goes on.to bad though it had no rust at all on it.even in the door jams and under the doors were rust free, hard to find here cause of the winter salf on the roads.I really didnt like the 5.0 it had in it anyway to me a bronco needs a 5.8 to have some *****.later.
Old 09-14-2009, 10:37 AM
fordbroncodave
the 5.0 has plenty of *****. its just the transmission that makes it feel like crap.
Old 09-14-2009, 02:09 PM
helirich's Avatar
helirich
helirich is offline
I hope I didnt scare you off. The ball joints are not really that hard, just time consuming. The ball joint press can be bought from Harbor freight or even barrowed from some auto parts stores. At the same time, you can check out u-joints, wheel bearings, brakes, hubs and seals.
A Bronco with perfect ball joints may be hard to find. But a Bronco with no rust is neerly impossible to find. (especially in Conn.)
I like the 351 for towing. But the 302 is a good engine.
Old 09-14-2009, 02:42 PM
fordbroncodave
northern states have much worse looking broncos then the west and east coast but the ones down south are way better then the best ones in minnesota.
mine was from new jersey in 2000 (assuming there was minimal rust), now it looks worse then the ones in the scrap yard. its getting rough but its also getting painfully difficult to control the rust. the factory bondo is chipping all over this.
Old 09-14-2009, 04:30 PM
alxsnmr's Avatar
alxsnmr
alxsnmr is offline
If the truck is rust free, ball joints are far cheaper to replace than a rusted out fender, tail gate, door jambs, and floor boards. If you didnt like the 5.0, a 5.8 upgrade is something else that is far cheaper than the rusted body panels, not to mention painting them after the fact. Not to mention the fact that the new ball joints are greaseable units unlike the factory ones that are non-greaseable.
Also, someone else mentioned that perfect ball joints are going to be harder to get, especially if the truck has had larger tires and/or heavy loads on the truck. These are wear items anyway, if you replace them now it is better than replacing them later when it is much less convient of a time.
Old 09-14-2009, 10:29 PM
greystreak92
I would check all that too but his question was regarding ball joints.
If ANY tires exhibit cupping in the wear pattern there is a problem. There is nothing about "mud" tires that makes them cup when any other tire won't. Sorry, but cupping is avoidable with a front end that is in good condition unless you are running tires that are just too big for the suspension to handle.
BigD7575
06-08-2012 12:31 PM
bigtexan99
07-31-2011 08:56 PM
kc 300EX
11-13-2010 10:56 AM
jhicken
05-05-2010 12:19 PM
jwshira0821
1999 to 2016 Super Duty
15
07-10-2009 08:36 PM
Quick Reply: how to tell if ball joints are bad?
