ABS Hydraulic Unit
I don`t think you can get a rebuild kit. Considered a non-servicable item.
As for models/years, `87 was the first year for RABS so nothing before that. So look for F250 or F350 from `87 up. They changed the computer around `92 but I think the hydraulic unit stayed the same up to about `97.
is this the unit located on the inside of the driver side frame rail? if so, mine was leaking on my '96 too and was in rough shape (very heavily rusted). i removed it and ran a standard brake line to bypass it. the ABS light on the dash stayed on, so i removed the bulb. problem solved as far as i'm concerned. no rear ABS, but thats fine with me. If you need the rear ABS, then this is not an option for you.
Adrenalin9699
10-31-2015 08:20 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
12-18-2014 07:33 AM
pbrooks259
11-15-2014 07:33 AM
pjnadon
12-19-2010 10:58 AM
