Overheating 97 F150
Overheating 97 F150
I have a 97 F150 4x4, 4.6l V8. It only overheats on a cold start. The temp gage goes to hot and the fail safe light comes on but after about a minute the gage goes back to normal and the light goes out. My cap does pop and I lose a little coolant from the res. bottle. I have changed the t-stat, water pump, radiator hoses, pressure cap, temp sending unit, cyclinder head temp sensor, and have flushed the radiator. Also I have noticed that my heater will blow cool air until the temp gage goes to hot and starts to return to normal then my heater will start blowing warm air. Could my problem possibly be my heater core or heater hoses.
i had a similar problem. found the thermostat was sticking. also i found out if i filled the antirfeeze tank to the full mark of an inch overfull, that expansion would make the tank go over pressure and cap leak. i now try to keep the level slightly under the cold full mark. have had much less problems. NO problems for first 3 years, no for some reason i have the high temp for 30 seconds then drops back to normal. New thermostat and slightly lower level has helped quite a bit.
scrobbie
1997 - 2003 F150
12-10-2016 02:37 PM
38Chevy454
Modular V8 (4.6L, 5.4L)
01-18-2011 11:08 AM
