Kerosene
Kerosene
Howdy, I was directed here with this query. Has anyone used Jet fuel, Jet A to be precise in an IDI 7.3 ? Jet A is basically kerosene and I heard you should either mix it with diesel or add motor oil (I am not sure what type) if it is used 100% - other than that I'm just looking for input. I can get the stuff pretty well free but don't want to cook some component.
It will run, but it has zero lubrication, you need a lubricative additive. If the fuel is free, you are saving enough to afford to use a good additive, I would double the dose each time. Where do you get this free, just out of curiosity, some kind of dumped fuel? If so, I would make sure to filter it good.
Thanks, not sure where I will get a lubricant additive (I live in a hic town and if you go into a shop and ask for something like that they look at you like you have a second head) but was hoping that the diesel 50/50 mix would be adequate - I was thinking maybe a mineral type of oil would be ok if I needed to add anything. The fuel I am getting is clean, probably more so than the stuff you can buy at the pumps.
Anyone wanting to use kerosene, or jet fuel for diesel need only add a few quarts of motor oil, or vegetable oil to give the kerosene the needed lubrication. Do experiment. If you find your engine over heating, then you need to add more oil. If you find your exhaust is dark and smoky then cut back on the oil.
blueeyedfordguy
Garage & Workshop
27
02-17-2014 11:23 PM
