1976 F-150 steering column problem...
Old 08-18-2009, 04:44 PM
yamanx's Avatar
yamanx
yamanx is offline
The shifter on my truck broke the other day. It's an automatic and I am at a loss on how to fix it. The part that the shift lever is on was broken, I ordered a new one from LMC truck and partially installed it and turned the shift shaft but it's not shifting the tranny. Any suggestions or where to get a used steering column?
Old 08-19-2009, 03:00 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Did you get the correct A/T shift collar?
D5TZ7228A .. A/T Shift Collar / Available from Ford / D5TZ7228A replaced C9TZ7228A & C5TZ7228B.
MSRP: $62.98 // FTE sponsor Y2KFORDPARTS.COM price: $45.35.
Fits: 1965/66 F100/250 / 1967/77 F100/350. 1978/79 is not the same.
Buying a used column: It may not be any better than what you have now, it could be worse.
Old 08-19-2009, 10:13 PM
yamanx's Avatar
yamanx
yamanx is offline
I found out when the collar broke it put all the pressure on the tabs on the shift tube and ripped one off. So I got a new shift tube in route, hopefully this will bring the beast back! Thanks for the help!
Old 02-02-2010, 04:25 PM
mdc4229's Avatar
mdc4229
mdc4229 is offline
where
where did you find the new shift tube????
Old 02-03-2010, 02:23 AM
yamanx's Avatar
yamanx
yamanx is offline
LMCTruck.com....
LMC Truck Parts - Pages 100 and 101
LMC Truck Parts - Pages 102 and 103
Are the pages in their catalog that have the tube on it.
Good luck!
Old 10-26-2016, 05:17 PM
jdgarner13's Avatar
jdgarner13
jdgarner13 is offline
I am having the same issue with a 1976 F150. I have the new shift collar and I know that the shift tube key is broken on the upper end. I can't find any info on the removal and reinstall of a shift tube. If you could point me in the right direction I would greatly appreciate it.
Old 10-27-2016, 11:13 AM
NumberDummy
Assuming your truck is 2WD .. the shift tube is shown as basic part number 7212 = A/T is different than M/T
three.on.the.tree
WTB - Parts & other
11-09-2017 01:32 PM
Uni Moe
08-06-2017 07:11 PM
1956_F100
03-07-2017 08:49 PM
scrobbie
47
04-17-2016 01:23 PM
T_Cooksey88
03-17-2016 11:23 AM
Quick Reply: 1976 F-150 steering column problem...
