How do I manually release pressure from air suspension?
Mike, yes they are the same setup. Just push in on the outer ring and pull the air line out. I used a jack under the hitch so when it dropped, it wouldn't go down. Just the air in the bags will depressurize. Don't forget to turn off your susp. control located above the kick panel on the pass side.
Cool. Thanks! The truck is on jack stands on the frame in front of the trailing arm mounts, and I turned off the switch before I started... but when I dropped the axle down there was still enough pressure in the bags they actually popped inside out at the bottom. I don't think it hurt anything, but hopefully once I get the pressure out I can push the bottom back up inside where it belongs. Thanks again for the tips.
Mike, sorry about that. After reading what you experienced I went out and crawled under mine to try to remember what I did. After disconnecting the air line and electrical connector, I removed the retaining clip and then turned the air spring solenoid (slowly) to relieve the pressure (just be very careful doing this). This is how I did it, not how the manual said to. I did mine during the winter time so I wasn't wasting time.
Cool. That's how I (eventually) did it too. I compressed the bags all the way up then put the springs back on- amazing how short they get. After the axle assembly was back in I turned on the key and suspension switch, and "tricked" the rear sensor so the pump would inflate the bags slightly, just enough to be able to put them in place on their "nubs" on the axle. Amazing how light those things are, and how they're just held on with a speed clip.
Since this is a completely different topic than the thread you have linked to you probably won't see much response. You should always start your own thread when you have a new issue.
That said, why do you want to replace the gas in your A/C system? It does not wear out. If you are having problems with your A/C system you should start a thread and put in some information on what is happening.
josiewales
07-02-2016 10:54 PM
1998, air, depressurize, expedition, ford, inflate, level, manually, navigator, pressure, release, releasing, relieve, suspension, suspention, system
