Shakes when take off
Old 08-12-2009, 05:36 AM
1992 F150's Avatar
1992 F150
1992 F150 is offline
No matter how smooth I let the clutch out first gear shakes, kinda hard sometimes! It's only first though. U joints? I tried to move the drive shaft at the u joints when the truck was parked and left in gear and there was no movement. When I leave it in neutral it moves. Not sure what's wrong, any help would be great!
PS, whats it take to clean up the slop in the steering wheel?
Old 08-12-2009, 07:55 AM
Volvo92906's Avatar
Volvo92906
Volvo92906 is offline
Cant help you on the shakiness but here... There is a whole thread we just got done with about loose steering.
https://www.ford-trucks.com/forums/8...-steering.html
Old 08-12-2009, 08:38 AM
danr1's Avatar
danr1
danr1 is offline
A weak pressure plate can cause a shuddering, only happens in first gear taking off and sometimes effecting reverse. Sometimes if reverse is low geared enough its not effected as bad if at all.
Old 08-12-2009, 09:03 AM
Conanski's Avatar
Conanski
Conanski is offline
A partially seized U-joint will cause this and won't be obviously loose. It's worth the effort to unbolt it and take it out for a closer inspection, just put a chalk mark on the shaft and axle yoke so it goes back in the exact same orientation.
Old 08-12-2009, 07:13 PM
1992 F150's Avatar
1992 F150
So I guess it'd be cheapest to see if it is the U joints first? There are 2 right? I'll use a Haynes manual to guide me so any pointers and tips would be great! Thanks,
Noah
Old 08-12-2009, 08:57 PM
oldblu65's Avatar
oldblu65
oldblu65 is offline
Shaking ?
I have an old truck that I've owned for a number of years ! It used to be my daily driver but it got to where the engine didn't run very well and it had a terrible amount of chattering when you tried to pull out no matter how easy you tried to do so . I always figured it was the clutch or flywheel causing it . As time went on , it was relegated to the garage and I drove my car everyday. About two years ago , I thought it was time to revive that old truck . I bought a V8 to replace the old tired 6 cylinder . When I pulled it out , I was surprised to find the actual cause of the chattering ! The bell housing was missing two bolts and the rest were loose ! When the new engine went back in , with the correct amount of bolts tightened to the proper torque , the chattering was gone ! My be worth checking your bell housing just to be sure !
Old 08-13-2009, 10:44 AM
xpl0sive's Avatar
xpl0sive
xpl0sive is offline
my truck does this too, it feels like its coming from the rear end, so my guess was the u-joits. i ordered two new ones, havent got a chance to replace them yet... also, when i'm stopped at a light and go to take off, it feels like the drevveshaft spins a bit first, then it clicks on and taks off... it feels like a THUD and i dunno what's causing it... is my rear-end on the way out or what?
Fish_Scientist
24
07-20-2017 10:57 AM
huntin_cowboy
15
03-02-2017 07:47 PM
SeaBassHWD
03-08-2016 09:00 PM
whitey33
01-25-2016 11:56 AM
79sparky
16
01-15-2012 08:52 PM
Quick Reply: Shakes when take off
