brake lights not working
The brake lights on our tow rig are not working. Its a 2002 F-450. The lights don't work on the truck or at the trailer so that tells me the problem is in the truck. Both rear turn signals work so the bulbs are good. I checked both fuses on the fue panel slotted for brake lights (18 and 34 i think) and both fuses are good and there is current to them. The brake switch by the pedal is good because the electric brake box for the trailer reads when i depress the pedal. At this point i'm stumped. I'm hoping there is a brake light relay somewhere that could have gone bad or more fuses than just the two on the panel beneath the column. I would think that a wire was bad going back but i thought current for the brake lights ran through the same wires as the turn signals and operates the same bulb. Anyone have any ideas?
I think you'll find another fuse/relay box under the hood. Somewhere on the driver side, fender well.
Brake lights and turn signals are all the same wires and bulbs, as you said, so I would look for that underhood box.
I would have guessed brake pedal switch, but you seem to have eliminated that already.
i found a small relay box with 3 relays in it but nothing beyond that under the hood, maybe i'm not seeing it. i would have thought that the brake lights would have a relay but there isn't one for them under the dash. If the electric brakes on the trailer work then the brake pedal switch has to be good right?
If the switch is a single pole switch, then yes. Sorry, I don't have that year truck so I just don't know.
Okay, remember, this is an '05 schematic. They could have done anything with wire colors.
The hot wire will be LT GRN/RED (means light green with a red stripe). The output wire will be LT GRN. This LT GRN wire should be hot when the pedal is pushed. The LT GRN wire goes up to your multi-function switch, through normally closed contacts, and comes out as ORG/LT BLU to the right side stop light, and LT GRN/ORG to the left side stop light.
By the way, does your high mounted stop light work (on the back of the cab)? This is important, so make sure it has a good bulb and see if it works. Because that is the same wire from the brake switch, but does NOT go through the multi-function switch. So, if the HMSL works, but the rear brake lights don't, that is a strong indication that the multi-function switch is bad.
If neither HMSL or rear lights work, then it's more likely the brake pedal switch. Also, the LT GRN/RED wire should be hot at all times, even with the ignition key off.
No brake lights. Problem Solved....2006 F250 Super Duty. My symptoms started when my truck was fairly new. I had an intermittent warning, TBC FAULT. After 115,000 miles I noticed that sometimes it was hard to get the shifter out of Park once in a while. Then the TBC Fault warning came on almost every time I hit the brakes. Somebody told me I didn't have brake lights including the third light. My flashers and turn signals worked correctly. I saw a goofy guy on You tube playing with his brake light switch located just above the brake pedal. Like him, when I physically turned the switch my brake lights came on. To remove the switch you remove a green safety cover from a clip, remove the clip, slide switch and pedal arm off and disconnect the harness. The only tool used was a small flat screwdriver. My part #F87Z-13480-AA cost just under $30 at the dealership. Inside the switch are three contacts, one must be for the brake lights, one must be for the shifter release.
Hey i just had the same problem with my 99 turn but no brake lights and after tracing and testing every wire from the pedal up it ended up being the gem module and a friend had the same problem with his 2011 and it was the module as well and it cost him 800 from the dealer and i got mine from the bone yard for 100, i hope this helps if you know someone with an 02 or an 03 you can try their module. i hope this helps you troubleshoot the problem
waverous
10-10-2016 10:10 AM
aronashley
07-07-2014 07:19 AM
MY68F250
18
04-07-2008 03:08 PM
