AM antenna problems
Old 07-30-2009, 02:20 PM
Cadence8's Avatar
Cadence8
Cadence8 is offline
Cool AM antenna problems
My 2007 Exp. exhibits AM radio reception problems that can only be antenna or antenna-connection related. FM is not an issue. AM will - always has - go a long period receiving as if there is no antenna connected (only picking up the strongest stations in a very limited area, not anywhere near normal), and then suddenly get normal reception. The head unit was swapped out and no difference. The dealer says he has checked the connection at the back of the radio and in the right rear quarter where the antenna is. AM antennas are usually built in to the radio case, not external or visible. But I know, because of the mass of metal around a car radio, that even for AM there has to be an external antenna. This behavior has to narrow the problem down to one or two things, and it is frustrating that the dealer cannot find it. Ideas?
Old 07-30-2009, 07:04 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
spotty reception is indicative of a loose antenna
have you checked the connections yourself?
I'm having a similar issue with my FM. I've just been too lazy to pull the dash apart and check the antenna connections. Been using my iPod/iPhone instead
Old 07-30-2009, 10:17 PM
berry1234's Avatar
berry1234
berry1234 is offline
I would pull the radio, spray some contact cleaner on the antenna end and work it into the radio a few times. Test the reception with the radio uninstalled but plugged in. You may have a cold joint on the solder on the inside of the radio.
wastingas
12-08-2012 03:00 PM
jowilker
2004 - 2008 F150
10-22-2012 04:45 PM
hokie93
09-29-2009 12:43 PM
BigRed1
Electrical Systems/Wiring
09-14-2008 09:37 PM
dmutsch
1999 to 2016 Super Duty
02-24-2000 11:45 PM
Quick Reply: AM antenna problems
