1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Parts diagram, front axle?
Old 07-29-2009, 06:55 PM
ReAX's Avatar
ReAX
ReAX is offline
Since I have a job again and I have to do some commuting, I want to do some work to the hubs. But while I have the hubs out and I have 75k on the OE parts, I'd do some other work. Anyone have a parts or exploded view diagram of the front axle. I'm thinking hub bearing assy, the two orings per side, upper/lower ball joints, axle seal and greasing the needle bearing. Any other suggestions of parts to be dealt with while things are a part?
Old 07-29-2009, 07:12 PM
ReAX's Avatar
ReAX
ReAX is offline
While I'm at it, anyone have some dimensions on the bearing assy grease adapter?
Old 07-29-2009, 07:32 PM
F350-6's Avatar
F350-6
F350-6 is offline
Don't like Guzzle's write ups?
http://www.guzzle7pt3.com/nblube.php
http://www.guzzle7pt3.com/allube.php
http://www.guzzle7pt3.com/transfer.php
http://www.guzzle7pt3.com/fdiff.php
If you still want the exploded view let me know and I'll see what I can dig up.
Old 07-29-2009, 08:34 PM
ReAX's Avatar
ReAX
ReAX is offline
I have better access to aftermarket parts and I was going to follow the needle bearing and hub lube when I got the parts. Transfer case was simple, and I have a mag hytech on the rear, and they were done with RP at 60k miles.
Exploded would still be helpful so I can sit at a computer and work up a parts list/price. I know dorman has the one (I think it's the hub) seal, but I haven't found the yellow in aftermarket yet, ball joints are simple Moog, TRW, Dana. National should have the axle seal, but I don't know what else I want to tackle so I don't have to pull it apart again.
Old 07-29-2009, 09:16 PM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Old 07-29-2009, 09:17 PM
Furian's Avatar
Furian
Furian is offline
Old 07-29-2009, 09:18 PM
Furian's Avatar
Furian
Furian is offline
Old 07-29-2009, 09:20 PM
Furian's Avatar
Furian
Furian is offline
Old 07-29-2009, 09:35 PM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
There's some debate on how necessary this is, but while you're all the way in there, you could also replace the axle u-joints. Mine still felt decent but I replaced them while I was in there anyway.
Old 06-23-2012, 05:07 PM
awwwsnaps's Avatar
awwwsnaps
awwwsnaps is offline
Regarding Hubs
When I drive, my front passenger side hub clicks and groans in protest to the simple load of driving. I slipped the transfer case into neutral (so i could rock it back and forth from underneath) and found that at certain points the assembly doesn't turn with the tire like the drivers side does, then it will click and start turning. What could be the cause of this?
Old 06-23-2012, 07:51 PM
brd7666's Avatar
brd7666
brd7666 is offline
Here is a PDF File that I put together for you. You will have to download it to see it. I wasn't sure which front axle you have, so they are both on here.
Old 06-23-2012, 07:59 PM
brd7666's Avatar
brd7666
brd7666 is offline
I just realized this thread is three years old. HAHAHA
Old 07-29-2012, 11:25 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Brd7666,
Thanks for posting that file. I have an F250 to pick up
that is missing the drivers side hub,spindle and arms.
I needed to see what should be under there before I
go see it the first time. I will be loading it on a tilt bed
trailer and towing it home. I was worried on just how I can
make something to load it with.
Thanks
Sean
Old 11-02-2012, 06:23 PM
NE14SAND's Avatar
NE14SAND
NE14SAND is offline
THANKS FOR LINKS!!!
Old 05-03-2020, 02:06 PM
Daniel n rocket's Avatar
Daniel n rocket
Daniel n rocket is offline
having issues changing the the hub vacuum seals. any chanche i could get a copy of your pdf's?
Thanks Danny
Quick Reply: Parts diagram, front axle?
