Does anyone have a list or source for TSB reports?
Old 07-20-2009, 10:03 AM
CarbonClear's Avatar
CarbonClear
CarbonClear is offline
Does anyone have a list or a source as to where I can find the TSB reports for the 2007 Ford Expedition? I'm about to be out of my warranty and I want to make sure all the recalls have been taken care of.
So far this have been a great suv to own and wish to enjoy many miles with her.
Thanks!!
Old 07-20-2009, 10:37 AM
berry1234's Avatar
berry1234
berry1234 is offline
There are a few places that sell access to full text TSB's. I don't know of any free sites. There are a ton of TSB's for the 07. Unless you have a specific problem that a TSB refers too, they are not needed really. Recalls are different. You can go to the Ford website or call a dealer and they will tell you if you have any recalls.
Old 07-21-2009, 11:14 AM
CarbonClear
Berry-
I just want to make sure all the little nuances with the tsb's have been taken care of before the warranty runs out. I'm hoping that my dealer has been up to date, when I bring in the truck in for service.
Old 07-21-2009, 11:31 AM
berry1234's Avatar
berry1234
Old 07-21-2009, 06:15 PM
eddiemoney's Avatar
eddiemoney
eddiemoney is offline
Originally Posted by CarbonClear
Berry-
I think you are missing his point. The only way to get a TSB taken care of is if you specifically request it. They don't affect everyone and aren't a safety concern. Recalls on the other hand should be done mandatory during your service, or at least discussed.
Old 07-23-2009, 10:46 AM
Baumbach's Avatar
Baumbach
Baumbach is offline
Thanks!!
I have most of the TSB's listed at...
http://baumbach.com/Expedition.htm
Old 07-23-2009, 11:22 AM
berry1234's Avatar
berry1234
Here are the latest ones on Alldata.com. There are newer tsb's out, just not on their site yet.
08-24-8 12/08/2008 Body - Sunroof Water Leaks During High Pressure Car Wash
08-24-7 12/08/2008 Suspension - Rear Load Leveling Leak Down
08-24-2 12/08/2008 Wheels/Tires - Steering Wheel Nibble/Vibration
08-23-11 11/24/2008 A/C - Climate Seat Function Inoperative
08-22-7 11/10/2008 Engine, A/T Controls - Driveline Bump When Braking
08-20-8 10/13/2008 ABS/TCS - TC Lamp ON/DTC C1277/C1278 Set
08-19-1 09/29/2008 Instruments - Fuel Gauge Reads Between 3/4 & 7/8 Full
08-19-11 09/29/2008 Suspension - Front/Rear Suspension Squeak/Rattle
08-19-4 09/29/2008 Body - Rear Power Windows Slow/Stick/Bind
08-19-3 09/29/2008 Drivetrain - Rear Axle Seal(s) Leaking
08-17-4 09/01/2008 Interior - Tick/Creak From Instrument Panel Area
08-16-14 08/18/2008 Engine Controls - MIL ON/DTC's P0345/P0349
08-14-2 07/21/2008 ABS/TCS - Sliding Car Icon ON/Flashing/DTC C1996 Set
08-14-5 07/21/2008 Body - Power Liftgate Inoperative/DTC B117B
08-12-9 06/23/2008 Keyless Entry - Transmitter May Not Operate
08-9-1 05/12/2008 A/C - Blower Intermittently Inop/Stuck On High
08-9-8 05/12/2008 A/C - Whistle Noise When Changing Temperature Setting
08-7-6 04/14/2008 Ignition System, Spark Plug Removal Instructions
08C03 04/10/2008 Campaign - Tire Pressure Monitor Reconfiguration (Limo)
NHTSA08V166000 04/08/2008 Recall 08V166000: TPMS Non-Compliance
08-5-1 03/17/2008 Audio System - Radio Won't Seek Sirius(R) Radio Channels
08-4-2 03/03/2008 Engine - Cold Start Drive Belt Whistle/Hoot Noise
08-4-3 03/03/2008 Emissions - MIL ON/DTC P0456 Set
08S03 02/06/2008 Recall - Inner Door Handle Spring Replacement
NHTSA08V058000 02/04/2008 Recall 08V058000: Inner Door Handle Spring Replacement
07-26-3 12/24/2007 A/C - Compressor Cuts Out in High Temperatures
07-24-8 12/10/2007 Ignition/Fuel Systems - Misfire on Steady Cruise
07C19S1 11/15/2007 Recall - Air Bag Replacement (Delivery Hold/Stop Sale)
NHTSA07V541000 11/14/2007 Recall 07V541000: Driver Air Bag Replacement
07-22-3 11/12/2007 Interior - Gap Between Headliner and Sunroof Panel
07-22-4 11/12/2007 A/C - Poor Seat Cooling Performance
07-21-6 10/29/2007 A/C - Climate Control Seats Inoperative
07-20-4 10/15/2007 Body - Popping/Snapping Noise From Driver's Side Mirror
07-18-3 09/17/2007 A/C - Compressor Failure
07-5-13 03/19/2007 Battery - Discharges After Vehicle Storage
Old 07-23-2009, 11:50 AM
berry1234's Avatar
berry1234
Hey Baum, how are things? Haven't seen you on here in a while. Hows the Expy?
Old 07-23-2009, 11:58 AM
CarbonClear
Thanks all for posting!
As for the tsb's
If I mention the particular problem , does ford as of yet have solutions for the problem at hand? Or are they just made aware aware of the problem and choose to or not to resolve it. I know this has been mentioned in other threads, but I still have issues with this (07-22-4 11/12/2007 A/C - Poor Seat Cooling Performance)
I have mentioned to the dealer that the truck is serviced at, but they seem to ignore it.
Thanks!
Old 07-23-2009, 12:27 PM
berry1234's Avatar
berry1234
TSB 07-22-4
11/12/07
POOR SEAT COOLING PERFORMANCE - BUILT BEFORE 7/16/2007
FORD:
2007-2008 Expedition
LINCOLN:
2007-2008 Navigator
This article supersedes TSB 07-15-5 to update the Service Procedure.
ISSUE
Some 2007-2008 Expedition and Navigator vehicles built before 7/16/2007 and equipped with climate control seats, may exhibit poor cooling performance in the seat.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Verify there are no diagnostic trouble codes (DTCs) and that the thermal emitting device and fan assemblies are working properly. Then use IDS to select the Maximum Output Mode. This will increase fan speed to provide quicker cooling.
1. Using IDS (equipped with release B51.5 or higher) normally ID the vehicle.
2. Select "Toolbox" at the top of the screen.
3. Select "Module Programming" from the menu.
4. Select "Programmable Parameters".
5. Select "Climate Control Seats".
6. Select "High Cool Blower Voltage" to change setting.
7. Select "Maximum Output Mode".
8. After the preference has been successfully changed, verify that the seat fan assemblies are operating according to the new setting.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
072204A 2007-2008 0.3 Hr.
Expedition/Navigator
Vehicles Built Before
7/16/2007: Check For
DTCs, Then Change The
to Maximum Output (Do
Not Use With 12651D,
12651D4)
DEALER CODING
CONDITION
BASIC PART NO. CODE
14C724 42
Old 07-24-2009, 06:39 AM
99expy's Avatar
99expy
99expy is offline
Does anyone have more detailed information on TSB#09-06-01: Internal Clutch Failure. I saw another post from IQ9 regarding this. I think I may have the same problem with the transmission when it "kick downs" and would like to have this information in hand before I go to the dealer.
Old 07-24-2009, 10:46 AM
berry1234's Avatar
berry1234
I don't have the print out for his but I had this done on my truck. It relates to the overdrive friction plates. When you accelerate you hear a chirping sound sometimes. They replace the friction plates with newer design and change the tranny fluid. It cured the chirping for me.
BTW, this problem will not throw codes. I had to drive with my tech twice so he could hear it.
mbkowns
2009 - 2014 F150
07-19-2019 08:00 AM
adman02
1999 to 2016 Super Duty
02-16-2017 06:30 PM
King Ranch
2015 - 2020 F150
01-22-2016 08:23 AM
Sheryle
12-21-2011 04:01 PM
mb4k
1983 - 2012 Ranger & B-Series
02-18-2006 11:35 AM
Quick Reply: Does anyone have a list or source for TSB reports?
