SYNC 2nd USB Port
Old 07-19-2009, 06:11 PM
anollmann's Avatar
anollmann
anollmann is offline
SYNC 2nd USB Port
Well, I finally found it while working on wiring up the video system (Arbitrator) in the console. The SYNC box is bolted to the bottom of the console, with the plug facing toward the passenger side. To get to it, pop off the trim around the front cup holders and around the shifter. Then removed the top paneling there that runs from the dash to the big center arm rest. There are then two screws holding the front of the console down. Remove those, along with the 4 screws on the sides. The front two are behind those little plastic covers and the rear two are exposed (just slide the seat forward and access from the rear) Then just lift up the back corner of the console and plug in your USB! I accessed it from the rear passenger door with the front passenger seat all the way forward.
Its nice having my iPhone wired up all the time and the primary USB still available for hard drive, thumb drive, or flash updates.
Just thought I would share!
Alex
Old 07-19-2009, 07:29 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
I am seriously considering buying the Sync Add-on pack.
But it is $549 and requires Dealer installation.
vice a JVC or Kenwood unit that has the same functions, touchscreen, DVD...alot of other stuff.
how good is the Sync setup?
Old 07-19-2009, 09:26 PM
anollmann's Avatar
anollmann
I really like it. I don't use any of the voice stuff, just the iphone/ipod interface and the bluetooth phone. I've heard getting the "add on" kit is not as good as the original. I would suggest spending the $550 on a good bluetooth phone kit and an ipod adapter.
Old 07-20-2009, 12:00 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
I'm a big fan of using OEM if possible...usually less problems
I like the idea of plugging a 8 gig thumb drive into that hidden USB port and not have to worry about it again
Old 07-20-2009, 05:23 AM
anollmann's Avatar
anollmann
Yes but in this case it is not truly OEM... Does the aftermarket kit include the microphones built into the mirror and the buttons on the steering wheel?
Forget an 8gb thumb drive, I've got a 320GB hard drive plugged in! Takes a few minutes to index but works like a champ
You really trust that dealership to install it???
Good Luck
Old 07-20-2009, 10:26 AM
berry1234's Avatar
berry1234
berry1234 is offline
Are you sure the add on kit is for the 2008? I heard only the 2008+ Navigator will work for the add on kit.
Old 07-20-2009, 07:48 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
it says for 2008+ Ford vehicles.
if not, then I can throw it in the Stang. so not really worried about not being able to use one.
The add-on come with a speaker you install into your mirror or sun visor. then something gets put on the dash.
The install can actually be done by anybody, but you have to let a Ford Technician plug in a laptop into the USB port. Then they visit http://www.syncmyride.com and do some PC voodoo.
edit: so maybe it was wishful thinking. The add-on only seems to work on 2009 vehicles. and even then, if the 2009 model was produced in 2008, chances are it won't work.
well crap.
Old 07-20-2009, 07:57 PM
heymrdj's Avatar
heymrdj
heymrdj is offline
I wish (yes this is a side note) that there was more MP3 accessories than for IPOD. Most all quality MP3 players use the open access communication protocol that windows media player stores music by. Even if you don't sync your music with WMP, an MP3 players OS most likely syncs by the same protocol when you turn it on, just like almost every digital camera stores images in a folder named DCIM. It should be easy for a carputer like the SYNC system to have just as much control over a normal MP3 player as a IPOD/IPHONE/ISUCK :P
SlickYamaha
1999 to 2016 Super Duty
58
01-11-2024 08:14 PM
thomastl
2009 - 2014 F150
20
09-21-2018 11:53 PM
Jerry Weigel
2017+ Super Duty
06-10-2018 10:48 AM
_red rocket_
6.7L Power Stroke Diesel
20
05-09-2015 12:03 PM
A/Ox4
13
07-29-2014 09:03 PM
Quick Reply: SYNC 2nd USB Port
