Connecticut Chapter Join Chapter, Leader:
Ford Oil Pan Replacement
Old 07-14-2009, 11:25 AM
jbilliel's Avatar
jbilliel
jbilliel is offline
I have a 2000 Excursion with the 7.3L and the dreaded oil pan rotting/rotted failure. I POR'ed it last year, but the pain is leaking badly and if a rock hit it I am afraid the pan will be ruined.
Anyone have any good mechanics who will work on the side to pull the motor and replace the oil pan?
Any suggestions appreciated! I am in central CT (Middletown area), but am willing to drive and leave it where neccessary. While the motor is out it will also need new up-pipes.
Old 07-23-2009, 11:48 AM
jbilliel's Avatar
jbilliel
jbilliel is offline
No one has any mechanics that are looking for work on the side?
Old 07-23-2009, 12:43 PM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
Sorry, but all my mechanic friends have more work than they can do. One is head mechanic at a utility company and he's always busy these days. And the other has a new kid and no time.
If you find someone who is willing to do one post up. I'm probably going to want/need a pan in the next few years.
Old 07-23-2009, 08:40 PM
Zookie400's Avatar
Zookie400
Zookie400 is offline
i think your offering the "wrong kind" of side work. thats a nasty job. i have needed to change mine for a long time now, havent yet, and im a mechanic!
Old 07-31-2009, 11:13 AM
Sonny Dee's Avatar
Sonny Dee
Sonny Dee is offline
Sorry to hear that.
I can tell you where not to go. I had a pan and rear seal amongst other work done and 4k miles, 5 months later the oil pan gasket is leaking along with the rear main worse than when I brought it in. Not an hour ago I just got back from a stealership in litchfield Ct and they want 1200.00 to replace the rear main and new gasket. I was informed that the 12 month 12k mile warantee that came with the job doesn't cover seals or gaskets. Dealer gonna cost 2 grand and if it isn't done right, you're going to hold your hand on your *** to get it re-done.
If you are forced to have a stealership do it, get it in writing if it fails they will fix it, no charge, if they won't, find a stealership that will. It leaves me with putting up a chain hoist and having a go at it, good luck.
andrew's64
15
08-21-2016 11:17 PM
bizzelj
04-12-2015 06:20 AM
2013 EBOOST BRAD
6.4L Power Stroke Diesel
12-09-2014 11:29 PM
6.9 BLUES
04-02-2014 12:21 AM
Awitte58
15
06-21-2011 08:36 AM
Quick Reply: Ford Oil Pan Replacement
