Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
Trans shifter cable.....
Old 07-12-2009, 04:00 PM
purcy8's Avatar
purcy8
purcy8 is offline
Unhappy Trans shifter cable.....
Hello everyone, I am experiencing an issue with my shifter cable. It had been shifting sloppy for a week or so and I went under to adjust the cable and discovered the housing assembly at the retention clip next to the tranny is not holding the cable. The cable is intact but the housing will not stay in place when moving the shift lever. The hold-down clip appears to be fully seated but it will not hold the cable and prevent it from moving with the shifter. When moving between gears now, it will not move the linkage, however the cable slides in and out of the housing. Is there a way to hold the cable without replacing the entire cable?
My truck is a 99 Explorer XLT, 4.0 SOHC.
Thanks!!
Old 09-24-2009, 02:59 PM
Bostonsound's Avatar
Bostonsound
Bostonsound is offline
I was adjusting the bands on my 2000 explorer and the tourqe wrench slipped and I snapped the plastic housing but not the cable in the same place that you are talking about. I tried to use Gorilla Glue but no luck and the entire cable around here is $ 103.00 so it looks like I am spending some quality time this weekend in my favorite junk yard!
Ztitan
55
03-31-2021 10:48 AM
ct50f1
20
02-17-2017 09:20 AM
cardsfanbj
1983 - 2012 Ranger & B-Series
02-25-2016 11:08 PM
schneidballs
07-22-2015 11:09 AM
cub102
06-11-2015 10:01 PM
Quick Reply: Trans shifter cable.....
