Cruise control not working...
Old 07-09-2009, 04:23 PM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
Hey guys and gals, I am trying to figure out why the cruise control on my 96 F150 isn't working. So far I have checked all the fuses and under hood connections, I replaced the shut off switch on the master cylinder. Any ideas?
Old 07-09-2009, 04:39 PM
redlightning93's Avatar
redlightning93
redlightning93 is offline
Does your horn blow?
If not it sounds like a Clock Spring.
Old 07-09-2009, 05:01 PM
Pkupman82's Avatar
Pkupman82
Yep, the horn works fine. I was wondering if it might be something in the steering column. I can't seem to find a good trouble shooting guide for this system anywhere.
Old 07-09-2009, 05:36 PM
Sportruk's Avatar
Sportruk
Sportruk is offline
Sometimes the module itself rusts up. It's on the driverside inner fender, with a cable that runs to the throttle body. You can remove the cover, which is the electronics of the module, and check to see if the drive motor is seized. I had to use a pair of pliers to loosen it and put some oil on the bearings.
Old 07-09-2009, 10:10 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Make sure all your brake lights work, if one is out the cruise doesn't work
Old 07-09-2009, 10:50 PM
mstngmikegt's Avatar
mstngmikegt
mstngmikegt is offline
Never have figured out what's wrong with the cruise on mine. Tried to troubleshoot last year and gave up. Even replaced the cruise module with what should have been a good (but never tested prior to install) used unit and still nothing. Horn works, no airbag light after start up and brake lights work fine. Really don't believe the clock spring is bad and sure don't want to go through the hassle and cost to just toss a new one in either. Oh, and had the master switch recall done too. Am really curious what you find.
Old 07-10-2009, 03:50 PM
Pkupman82's Avatar
Pkupman82
Thanks for the replies guys I'll have to do some more checking. Any more feedback is appreciated.
Old 07-10-2009, 04:55 PM
subford's Avatar
subford
subford is offline
Here is some hints on Fords Speed Control, do not know much about the GM cruise control.
Old 05-02-2010, 01:38 AM
devyn88's Avatar
devyn88
devyn88 is offline
1984 f-150 2wd cruise not working horn is
i have a 1984 f-150 and i recently replaced my crise control panel/horn bar and found out my horn and cruise didnt work i traced the horn problem to a relay under my dash but still havnt figured out the cruise though.any sugestions?ps fuses are all good.is there a seperate relay?if so where is it hiding?
Old 05-02-2010, 06:15 AM
subford's Avatar
subford
subford is offline
There is a module under the dash that operates the Speed Control.
I do not remember where it is on a truck but it is near the steering column on a van.
Old 05-10-2010, 03:16 PM
steves_F350_460's Avatar
steves_F350_460
steves_F350_460 is offline
Can anyone tell me what the cable / connector looks like the the cruise control module? I think I have the cable, coming in the firewall and leads over to where the ECM is mounted, but no box or module for the cruise .......... ALSO, I'm having brake trouble with the pedal going all the way to the floor, and NO fluid loss anywhere, was told it may be the ABS module ........... then I heard that the ABS & cruise control systems share the same modules .......... it gets does get easier ... right ? My truck is a 88' F-350 with the 460 efi and c6 transmission. PS: there is an ABS sensor mounted on the upper part of the rear differential !
Old 05-10-2010, 07:17 PM
subford's Avatar
subford
subford is offline
The cable going from the transmission to the speedometer has a generator half way and the wires from it go to the Speed Control Module.
Maybe the ABS valve but not the module.
No they have different modules.
Old 05-10-2010, 08:22 PM
steves_F350_460
Thanks subford. WHERE IS THE ABS VALVE LOCATED ON MY TRUCK? Plus, I'm not sure my truck even came with factory cruise control, at least the steering wheel presently in the truck doesn't have the function buttons for cruise OR the tilt feature normally found as a combo'd pair of options from FORD, so maybe the thing never had cruise, BUT, there is a 3 prong female electrical plug / wire coming in through the firewall and tucked behind the left side kick panel in the area of the ECM unit ..... I just can't figure out what this thing is ????
Old 05-11-2010, 09:49 AM
subford's Avatar
subford
subford is offline
Maybe these will help:
Old 05-11-2010, 10:15 AM
steves_F350_460
Yes, helps HUGE !!!! What manual are the diagrams from? Chilton's ? I'll have to pick one up to be sure. I don't see the electrical connector I'm referring to in any of the diagrams. I think the truck must have had trailer brakes at one time and the connector was used to hook up the brake controller inside the cab. None the less. I did find the ABS module under the dash and is connected to the harness. My brakes still fall all the way the floor with not much resistance, until the last 1/2 inch maybe before I get any braking action at all. NO fluid leaking anywhere, so there must be a "brake system" component failure, just need to figure out where it is. Thanks again for the post.
Quick Reply: Cruise control not working...
