2001 Ford F150 EGR code P0401
Old 06-27-2009, 08:19 PM
Bert01F150's Avatar
Bert01F150
Bert01F150 is offline
Cool 2001 Ford F150 EGR code P0401
A while back my truck had code P0401, insufficient EGR flow. I cleaned the EGR valve, tube & all vacuum lines. I had no vacuum, Recently I got the same code. I followed the same steps as before. I now have vacuum but the truck loaps really bad with line connected to the EGR valve. If I disconnect the EGR valve vacuum line, the truck seems to idle a little better. Can anyone make any suggestions as to what could be causing this ?
Old 06-29-2009, 10:23 PM
BrianA's Avatar
BrianA
BrianA is offline
Hi, and welcome to FTE and the 4.2/3.9 Forum.
There have been several posts here over the years regarding P0401 (and P0402) codes.
While in the 4.2 forum, Click on "Search this forum" the top and type "P0401" in the search box. You'll get plenty to read.
I seem to remember 2 most common causes:
bad DPFE sensor
or
clogged EGR ports
Best of luck with repairs and let us know what you find as the cause.
bobbydee
1997 - 2003 F150
10-21-2016 02:39 PM
Al_Cuevas
1997 - 2003 F150
93
08-13-2016 08:50 AM
BRONC-OH
1997 - 2003 F150
06-12-2016 01:53 PM
mredington
1997 - 2003 F150
12-04-2015 07:23 PM
REGGIE_OBE
1997 - 2003 F150
10-16-2015 06:20 AM
Quick Reply: 2001 Ford F150 EGR code P0401
