C1 axle
C1 is LS. That's what I have. Are the tags on the rear-end in bad shape where it can't be read? Either way it won't hurt a non-LS axle by putting in the friction modifier. No clutches to help slip! Just don't put in too much. If you do, you have converted your Limited Slip to Limited GRIP! AKA an open diff...
That's the simple explanation. In turns the LS, with proper amount of friction modifier, will release the outside wheel other wise it will try to drive it at the same speed as the inside wheel and that is what causes "chatter". The outside wheel needs to move faster because it is going a further distance. If the clutches don't release the outside wheel moves slower or in a sense it is locking and releasing, that's what causes the "chatter". That is the nice thing about LS verses most positive drive diffs.
kappajoe
04-29-2016 09:53 AM
fslay
09-14-2014 05:34 PM
DDOG
04-04-2005 11:08 AM
irondragon79
03-27-2002 11:00 AM
