Mpg 7.5l 460
ok, what gears and trany?
A 96 will have an OD. so depending on gear and trans type, I would say 6-12. If you plan to do a lot of towing you my want to go with a 99- NBS
truck with the V10. I have both the 415 V10 and 460 big block v8, and the 460 just does not compare. My 460 is a 4bbl, so yours may be way better.
I have a 94 F250 Supercab longbed with fiberglass shell, 4X4, E4OD, 4.10 gears. Your mileage will vary a lot depending on options, gearing etc.
I typically get about 10-11mpg for mixed around town with freeway driving, IF I go about 50-60mph on the freeways. If I go over 70(Almost required around here) it drops to maybe 9mpg. Almost doesn't make a difference how I drive as long as I am not stuck in stop and go or going something like 80mph. Best I have ever seen is maybe 13mpg downhill on a tail wind drafting a semi. Speed appears to be the mileage killer with my rig, lots of wind drag.
With my 8,000# trailer I get something like 8-9mpg on steady flat land driving at about 60mph. Worst I have seen is around 5-6mpg hauling the trailer up long steep slopes like the Grapevine in Calif.
I use synthetic lubricants all around but my log book doesn't show me any mileage improvement that I can clearly point to.
Just my experience,
Jim Henderson
Just my experience,
Jim Henderson
Ok, that gives me a better idea. I want something for a fun truck, some off roading and such, but also need to get something I can plow with in the winter. I love the truck, but almost wonder if I need to look for something with the 5.8L. How big of a difference do you think there really is? Both gas wise, and power for what I want to do with it
